Yeah This is everything ready to go.. not really willing to sell without the loome ecu etc... but feel free to make an offer... as i said i have pics, just need someone to host them..
would prefer to sell it as a package.. an inspection is welcome and when you look at it you will know it is low km, as every aspect of the motor, looks new...
ring 0408207356 after 6pm ONLY!! lol.. ask for webber
Yeah sorry mate, i should have said, all the mouldings & interrior parts have been sold, there really is only loomes and things left.. when i said ask about little bits and pieces i meant the buyer of the package, so they have all the bits and pieces they need for the motor, or a conversion...
regards webber
Ok, final attempt to sell it... $5500 with all the brakes, the diff to suit fuel tank and lines, tailshaft. (front rotors booster master all)
(i had the rear end of the car stripped before i imported it and was going to use it also, but now have got onto all GTR items)...
will supply pics if someone will host...
OR will seperate if all the parts get sold....
Motor $3700 (all associated loomes to it)
box (triptronic) $800 (all associated loomes)
Brakes $750 all rotors, callipars, booster, master, lines everything
fuel tank $150 (including pump sender etc & fuel lines) (pick-up only)
Interrior loomes & non engine or transmission related loomes $170
Power window switches (like new; silvery ones) $250
Centre gauges displaying temp, oil & turbo pressure $320 (silver face)
also have the roof was gassed off, so if anyone has had a tree fall on theres or something stupid, is perfectly straight etc..
$offers
But as i say, i will only seperate if i have a name next to every item as sold (well the majority)
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
