The ACL's are a good bearing, the race series bearings have a hardened steel backing which keeps them well located in the housings even when they have had some heat. They are fairly soft which is a good thing if there is anything floating around in the oil as it can embed in the bearing. They are not hard on the crank either, not really an issue with an RB as the crank is pretty hard to start with.
I still prefer King bearings, the material is better, only one layer of bearing material about .015" thick on a super hard backing, the alecular material has a melting point almost 3 times higher than the babit on a regular trimetal bearing so there is less chance of delamination even under extreme loads and heat.
Nissan bearings are made by NDC and are a trimetal bearing, I have seen these delaminate when they cop some detonation. I haven't used Nismo bearings, I'm still pretty sure that they are a trimetal bearing, one benefit I suppose is you can buy them graded to adjust clearances but then if the bearing housings are not on size they should be remachined anyway. I haven't had problems getting spot on clearances with the king bearings, all the bearings in a set are guaranteed to be within .0001" tolerance so there is no chance of tolerances stacking up and changing clearances. The other benefit of Kings is the price, they're cheap as dirt compared to Nismo bearings as they are a standard replacement bearing.
The HX bearings run an extra .001" clearance over the H series.
Yeah..thanks for that. I guess ACL reccomend the extra clearance for the 26 because they typically make a bit more power than the RB25.
When they say 1 thou extra clearance, any idea what the clearance will come out at with a brand new crank?
Cheers.
ok cool ,
so who sells King Bearings and what kind of cost we looking at for a set of bigs and mains.
on another matter the nissan specs clearances are pretty damn good
ie there factory spec 0-3 for main tunnel and main journals is only
+/- 0.0005" for the 4 spec sizes or a mass producted engine thats pretty impressive and no wounder people dont have many problems with tolerances even with out using the 6 grades of nissan bearing.
pete
It has had the alloy plugs that seal off the oil galleries in the crank removed and been tapped to take screw in grub screws to seal the galleries. You need to remove the old plugs when you rebuild the engine to clean the crank properly.
It's a good thing, whoever did your engine did it properly, it doesn't affect anything else.
Warning!!! ACL PRODUCT WARNING. Were supplied new race series forged ACL pistons, rings and bearings for an rb30/25 hybrid. Engine built buy a reputable engine builder and run in by ex Perkins engineering mechanic/tuner. Rattled from new and pulled down at 2000Klms to discover massive wear on the drive side of the bore. Piston to bore clearances measured at 7 tho and within spec. ACL denied refund/replacement and rolled out these excuses in this order. 1. Detonation (cleared after hardness test) 2. Foreign substance in bore (brand new engine run in on dyno with standard air box and new filter) Cleared after excuse number three. 3. Over boosting causing rings to break down and cause abrasion on bore. (Stat decs signed by engine tuners engine stating run in boost set to max of 14psi). ACL now tell me that there FORGED race series pistons are only rated for 10PSI. This engine has a comp of 8.2:1. Standard engine runs 9:1 with cast factory pistons at around 9psi...do the math. Currently taking legal action. Any questions regarding this "race designed product" PLEASE contact me @ [email protected] .This is not a rant, but an opportunity for other people to learn from experience.
7 thou clearance thats f**king hugh what is there recomend clearance on install out of interest
  • 5 years later...
hi there i am in the middle of building a rb30/26 and wanting to use acl race series bearings but they are on back order i have the option of using th hx bearing which give 001" extra oil clearance are there any pro and cons to using these or should i wait for the standard one which will be weeks
ACL are in Liquidation, so stocks are pretty much Zero on things, the extra clearance will help if you want to rev it fairly hard or want to run big power, (if its a 26/30 than I assume you want a fair whack of grunt)
  • 1 month later...
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
