Bl4cK32 Posted October 9, 2005 Share Posted October 9, 2005 Below is two pics of the GT35r (GT35/40R) turbos. The one on the left has the .5 front cover as it came off the ford xr6 turbo. The one on the right has a .7 front cover supplied aftermarket. The turbo on the left (.5 ar front ) has a hose going from the actuator to a bung on the compressor cover, where the 0.7 cover one on the left doesnt have this at all. Where do you need to attatch the hose coming off the actuator if you have the 0.7 front cover?? Somewhere after the outlet of the turbo on the pipework? Thanks Link to comment https://www.sau.com.au/forums/topic/90432-xr6-gt35r/ Share on other sites More sharing options...
Lazy-Bastard Posted October 9, 2005 Share Posted October 9, 2005 either to your inlet piping or boost control solenoid if you have an ebc Link to comment https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1629819 Share on other sites More sharing options...
Bl4cK32 Posted October 9, 2005 Author Share Posted October 9, 2005 (edited) cool. Now for another question Is it just a simple job of swapping the 0.5 cover for a 0.7 cover between the two turbos? Ive heard so many people say they are different specs, but are they different, or the same? ie, if i bought the one on the left, could i unbolt the front cover and swap it for a 0.7 ar front? Thanks Edited October 9, 2005 by Bl4cK32 Link to comment https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1629830 Share on other sites More sharing options...
discopotato03 Posted October 9, 2005 Share Posted October 9, 2005 No , the .50 cover is T04E series where the .70 is T04S series . You would need to change the back plate/adapter ring as well . These butt up to the flange on the comp side of the cartridges bearing housing , are sealed with an O ring and held in place by a large circlip . Try to buy it as you want it because the bits are not always cheap , when I inquired through GCG Brett said he could supply any of the three .50/.60/.70 "E" covers or the .70 S cover for the same price . Cheers A . Link to comment https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1629994 Share on other sites More sharing options...
Bl4cK32 Posted October 9, 2005 Author Share Posted October 9, 2005 thanks disco, your help is appreciated always Link to comment https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1629997 Share on other sites More sharing options...
mr_rbman Posted October 9, 2005 Share Posted October 9, 2005 will this be on your car by the dyno comp on the 22nd darren? would be awesome to see the figures of this baby! Link to comment https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1630134 Share on other sites More sharing options...
Bl4cK32 Posted October 9, 2005 Author Share Posted October 9, 2005 lol...not yet still getting the exact turbo specs i want organised I'll post dyno results when its on though... Link to comment https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1630501 Share on other sites More sharing options...
Bl4cK32 Posted October 10, 2005 Author Share Posted October 10, 2005 Ok, now ive got a good question disco (or anyone else) : what is the difference between the T04E and the T04S covers...and when comparing same size covers - 0.5 T04E vs T04S? (Also disco, what would you say would be the best on my motor, the 0.5, 0.6 or the 0.7? What would be the difference in power spread over the 3 covers? Link to comment https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1632295 Share on other sites More sharing options...
mr_rbman Posted October 10, 2005 Share Posted October 10, 2005 mmmmmm, can't wait to c the results! Link to comment https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1632458 Share on other sites More sharing options...
Dobz Posted October 12, 2005 Share Posted October 12, 2005 If you're looking to make fairly big power figures i.e. 300kw plus then you'd want to keep the .7 cover for the simple fact that it efficiently flows more air which is whats needed for big power and turbo reliability. Anything under 300kw the .5 cover would be fine but thats pushing it. Link to comment https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1637173 Share on other sites More sharing options...
Cubes Posted October 12, 2005 Share Posted October 12, 2005 (edited) hrmmm .6 you say disco. I would still prefer the .5, you will need all the response you can get with the 1.06. The XR6 boys don't seem to have trouble cracking 320-340rwkw on the .5 comp cover. More than enough for the stock rod rb30. Then again... The .7 comp gt35r 1.06 turbine will still have better response and spool time than an rb20det with a highflow or 2530 on it. Edited October 12, 2005 by Cubes Link to comment https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1637534 Share on other sites More sharing options...
Bl4cK32 Posted October 13, 2005 Author Share Posted October 13, 2005 If you're looking to make fairly big power figures i.e. 300kw plus then you'd want to keep the .7 cover for the simple fact that it efficiently flows more air which is whats needed for big power and turbo reliability.Anything under 300kw the .5 cover would be fine but thats pushing it. <{POST_SNAPBACK}> Well i guess you should talk to GCG then, as they think differently. I emailed them and they said : Thanks for the enquiry. For an RB30, I would suggest using the 0.60a/r Compressor Cover for your application. The difference between the 0.5a/r covers throughout the the T04 Range is the inlet and outlet sizes, and designs of the covers. They would all work in the same way, and produce similar, if not the same figures. We have had good success with people keeping the standard 0.70 T04S Compressor Cover, but you can drop to the 0.60 for better response This is on a street driven car. Link to comment https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1639618 Share on other sites More sharing options...
Cubes Posted October 13, 2005 Share Posted October 13, 2005 (edited) Well my guinea pig.. GET TO IT! You gotta walk the walk if your gonna talk the talk. Edited October 13, 2005 by Cubes Link to comment https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1639940 Share on other sites More sharing options...
Col-GTSX Posted October 14, 2005 Share Posted October 14, 2005 I would use it as is.... I mean try and if no good then swap em over.... There is just too much hear say on these topics.... I was told a standard r33 turbo on an rb20 would not produce a cent over 180rwkw and i got it too 230rwkw.... So who know's???? I would take Bretts advice as a starting point but if your un happy with the results you can always change it.... Link to comment https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1640890 Share on other sites More sharing options...
Bl4cK32 Posted October 14, 2005 Author Share Posted October 14, 2005 I would take Bretts advice as a starting point but if your un happy with the results you can always change it.... <{POST_SNAPBACK}> Well considering he has a rb30det, id say he knows what hes on about. As for being the guinea pig....im runnin not talking Link to comment https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1641896 Share on other sites More sharing options...
Cubes Posted October 14, 2005 Share Posted October 14, 2005 Just remember, lag and spool time is very subjective. I am very sensitive to lag. Link to comment https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1642259 Share on other sites More sharing options...
Col-GTSX Posted October 15, 2005 Share Posted October 15, 2005 Its hard to say whats perfect so you need to try to find out.... But its in 0.5 form now so its easier to try as is before pulling it apart.... Is what i trying to say.... Link to comment https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1643458 Share on other sites More sharing options...
Cubes Posted October 15, 2005 Share Posted October 15, 2005 (edited) Fatz made 270rwkw on 14psi with an untouched rb26 ecu running 10:1 afrs. If the motor has forged rods then I would say the .6-.7 a/r cover would be worth while. Remember with the .5 on the 3ltr its not going to really start going until 3800-4000. Is it worth making it even laggier and less responsive? Edited October 15, 2005 by Cubes Link to comment https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1643473 Share on other sites More sharing options...
Bl4cK32 Posted October 15, 2005 Author Share Posted October 15, 2005 I'll trust fact that GCG know what they are talking about. Ford used the 0.5 front as it was a low boost application to keep the power down. (am i right...lol?) I think the slighlty bigger compressor (0.6 front) will be a bit better for a little more (14 to 19 psi) boost than Ford was running. If i wanted more boost again (ie 20+ psi) id go for the 0.7 front....thats my theory anyway, and im sticking to it Link to comment https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1643533 Share on other sites More sharing options...
Cubes Posted October 15, 2005 Share Posted October 15, 2005 (edited) The reason Ford used the .5 comp cover is for response, nothing to do with keeping the power down or because it is a low boost application. There is no doubt the larger comp cover will be more efficient and make the power easier but not that much. As a bodgy comparison... Consider the GCG highflows, the stock rb comp cover makes say 245rwkw odd. Slap on a .7 and it makes 260rwkw. Thats 15rwkw. Then consider dropping on a larger turbine housing, 245rwkw or so jumps to 277rwkw. What I'm getting at is the biggest gains are to be had from the turbine side, not the compressor cover. From what I've been reading up on, the larger .7 comp cover only offers 3-4% increase in power. I really think your better off spending the $$ on a nice set of cams and springs that will need doing and pick your self up a second hand $1400 XR6 turbo. Cams with the large turbine housing will work very well. I think from more of a performance to $$ point of view. Edited October 15, 2005 by Cubes Link to comment https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1643658 Share on other sites More sharing options...
