Hey this engine isn't mine just one I found on the net to illustrate my question. On my car the hose i've circled below has been removed and the ends where it joined on have just been sealed off with big rubber cap things. Just wondering why this would've been done, and if I should remove the caps and rejoin the hose. I remember the engineer who looked at it when it was imported said i should fix it cuz it could end up blowing my engine up or something.
Edited by Lithius
So what they've done is block off the stock BOV? Where does the air go instead? Any idea why they would've done this?
I'm just wondering if I can take the caps off and put a little bit of hose in there to rejoin it all. Or whether I should even just leave it how it is... If the BOV isn't hooked up how does it release pressure?
Edited by Lithius
I met a guy a while back who swore on his life and bet his balls that bovs decreased performance and hurt the engine, no matter how much i argued with him, he couldn't understand.
Sorry, just thought i'd mention that.
Bov's definitely do not hurt the engine.
Having no bov doesn't hurt the engine either.
There is the issue of having no bov causing compressor stall when you jump off the throttle, causing it to have to spin up again.
When making shiet loads of power some have noticed a decrease in lag between wot gear changes by running a larger bov.
Who knows.. Who cares.. :)
The theory is that the BOV allows to compressor to keep pumping during gear changes and times of closed throttle.
On full boost and WOT, the air from the turbo compressor is flowing into the engine. During a gear change, the throttle snaps shut, blocking off the path for the air into the engine. However, the compressor keeps pumping. Eventually it will reach the limit of its capacity to pump air and start to slow down. So when the throttle opens again, the compressor needs to spool up again.
Now, if you release the pressure, via a BOV, the compressor can continue to work at optimal performance. So when the throttle opens again, the compressor is still at it's optimal speed and pumping capacity, gaining immediate response from the engine.
I'm sure if BOV's detracted from perfomance, the manufacture's would not have invested millions of $$$ developing the engine with a BOV attached.
Thanks for all the input guys.. I joined it back up with some radiator hose type stuff, does seem to be a bit nicer between gears when i'm giving it a bit. So there's nothing else they would've changed to complement that? Like the electronic boost controller and stuff will still be fine?
yea you should be right, by the looks of it the person before you simlpy turned the BOV into an atmo one. This does not effect your turbo but it would make you car run rich and possibly stall due to incorrect air flow meter readings.
Anyway, this is an easy fix and there should not be any other BOV related things for you to worrie about.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
