lets make a date to meet up and go with it ...ive been doing this up for nearly four years in that time this car has probably done 4000 km everytime i finish one thing i find another thing to do and its always off the road waiting fo parts ...... it never ends.... but the reason i am putting the 6 speed dog box i am after 800 hp with the twin td06 set up .....
the need for speed....
  • Replies 109
Posted Images
i have 19'' wheeles so traction is a thing of the past but on the track i have micky thompson radials.... its still only single turbo i am still waiting on the other one from the land or the rising sun...
Absolutlly love it.....
Looks horn under the hood.....
Similar to what i have planned and have purchased....
I do wish to know a little more about the ignigtion system....
What coil pack are u using and its the MSD controller.... How did that work out.... I assume a map sensor was introduced but what sort of ecu are you using now???
post-7531-1129380872.jpgpost-7531-1129380945.jpgawsom its got 14k worth of upgrades running digital 4 ignition 6 v8 supacoil packs 3 seperate bosch ignighters with two msd amplifiers all up putting out about 450000volts tell me thats not enough spark....
post-7531-1129455922.jpgpost-7531-1129456097.jpgwell i bought the gts and started doing some mods i put a few things like motec m8 pro race seats actually pritty much the same as in the pics exept i had a t51rspl and payed a guy to do all the work but instead he sold all my parts i went to c the car he wasnt home went out the back and their it was stripped nothing left but a shell ... but of coarse he told the investigaters that i took everything so they said his word against mine so i got nothing ...so instead of a shell i re did it back up to what it is today with what was stolen it owes me around 120000i no its alot for a gtst but i love it and i couldnt just waste a r33 so thats the story .... if someone buy the name of george ross lives in ferny grove wants to work on your car not a good idear...... it took nearly three years to get it back to what it is now ..i dont have anypics of the interious but emagine a empty inside ...
ohh man thats one story we dont like to hear hey
how 'good' are these coppers we have these days, u reckon it woulda been a different story if it was an owner of a brand new ferrari and the owner was some famous business man
i look foward to seeing it mate :)
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
