Item: Garret GT30R turbo (.60 A/R)
Item Condition: Good as new, still currently fitted to car
Reason for Selling: Too small for recent engine/gearbox upgrade
Price and Payment Conditions: $1250 ono
Contact Details: Anita 0409 581 787
https://www.sau.com.au/forums/topic/90638-garrett-gt30r-turbo/
cheers - thank u B)
just recently got 3ltr bottom end - 9.0:1 compression, c4 gearbox - manual shift, forged pistons etc.
had it dynoed with this turbo on Monday - made 430rwhp on about 18psi...
does not suit this setup @ all tho, only reason 4 sale - way too small
the turbo was actually fitted 2 the car around 10 months ago, but my car has been off the road 4 about half of that time getting mods etc.
it's safe 2 say the turbo has only been used 4 about 4,000k's - good as new
obviously it would be t3 flanged?
Is it ball bearing?
Cheers.  Sorry bout all the questions.  but im very interested in it.
I'll answer this question 4 u. Q1) yes it would be T3 flange. Q2) it is a roller bearing turbo.
:-) im bord lol
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
