Can u guys help me out on this one because ive got no idea. Ive got a sky and need some help on the fluids that are recommended for it.
I know that engine oil should be changed every 5000kms with good full synthetic oil as well as have the oil filter changed.
What about
- transmission oil
- radiator coolant
- power steering fluid
- brake fluid
Can u use any type of fluid or do u have to use special ones that are specifically designed for high performance cars???
Some recommendations on the fluids u guys are using for your Lines would be appreciated
thanks
https://www.sau.com.au/forums/topic/9101-engine-fluids/
I use Silkolene DOT4 for my brakes. Its damn good compared to the crappy Mobil and Castrol that regular auto shops stock.
Good sources for quality fluids, both transmission and brake, is motorbike shops. They stock really good brands like Motul, Belray and Silkolene. One type of racing brake fluid Silkolene make retails for about $38 for 500ml's! I use the cheaper $16 dollar one which is good enough for most people id say.
Generally i change brake fluid once a year, but I dont do alot of motorsport, so it tends to get changed when I can feel the pedal is horrible. :D
I use Mobil 1 10W/30 in my Skyline for engine oil.
Red17
https://www.sau.com.au/forums/topic/9101-engine-fluids/#findComment-136994
So engine oil doesnt really matter which ones u use just as long as they are full synthetic rite?
thanks for the brake fluid tips i think ill hope down to my local bike shop and pick up a bottle of that stuff.
With transmission oil and brake fluid do u have to flush it or can u just top it up???
Sorry to be a hassle but one more thing guys...do you have to flush the radiator coolant or can u just top it up with Nissan's radiator coolant when it gets low
Thanks again
https://www.sau.com.au/forums/topic/9101-engine-fluids/#findComment-137497
You can just top it up I'd say...but every now and then (maybe once a year) do a full flush, because often stuff can just sit at the bottom of the radiator. Once i thought my radiator was clean (and the water was), and heaps and heaps of crap came out of it.
https://www.sau.com.au/forums/topic/9101-engine-fluids/#findComment-137553
Skyline_Paul: I just changed the oil in my gearbox and they feel as smooth as silk. I used Caltex Gearlube 70w-90 coz thats what they recommend for the car and its well worth it (used about 3.5 litres)... no more nasty clunking. For the engine I used 5w-40 Full synth (nearly used 5 litres). For the gearbox all you need is a 1/2 inch rachet (the square bit opens the bung) and the motor you need a 14mm ring spanner or rachet depending on what you perfer.
Filter for motor No. 145a
Petrol Filter Z200
Cheers
Sumo
https://www.sau.com.au/forums/topic/9101-engine-fluids/#findComment-147598
Hey Sumo thanks for the help i havent yet changed anything on my car yet...since i just got it the other week
just wondering how long should u leave it until u have another gearbox oil change? (kms??)
and also are u from the west cause i need some help...i am crap when it comes to car engine maintenance
cheers
https://www.sau.com.au/forums/topic/9101-engine-fluids/#findComment-150214
Im in Country NSW. Near Tamworth.
If you had all the filters and oils would only take half a day to do max.
Changing the oil in my Diff today, EP 85w-90 was recommended for the R32 GTR, but it reads its not recommended for LSD's? Im not sure whether the R33 is a LSD or not?.
Sumo
https://www.sau.com.au/forums/topic/9101-engine-fluids/#findComment-152089
Oil Filter = Z145a
Fuel Filter = Z201
Air Filter = A360
If you have and Auto you are best to change the Trans Fluid and filter every 50,000k's. If you have and LSD, which all Turbo Skylines have you should change its fluid with the trans flud. An lsd is almost useless if the Fluid is maintained. Manual Trans Fluid should really be changed at 50,000 to 60,000k's also just to b safe, especially if you drive it hard. Coolant Should be changed every 2 to 3 years and Brake Fluid every 2 years. Power steering fluid really should last you 100,000k's.
Im fairly sure the pads on all skylines are:
Front = DB1170
Rear = DB1220
Discs; (Not 100% sure if these are right for r32 GTST)
Front = DBA4963
Rear = DBA908
I use NGK BCPR6EVX Plugs in my R33, but if you drive hard you should use a 7 heat range. BCPR7EVX
https://www.sau.com.au/forums/topic/9101-engine-fluids/#findComment-169010
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
