i bought a r33 gts-t from the auctions. sounded sweet, drove fine. Got the 100,000 service and mechanic said its fine. then i started noticing shocking fuel consumption!!1 like 290 off the whole tank and alot of black smoke on the muffler. ive driven it for a month and decided to check the oil and its almost all gone :S
does this mean the engine is dead? or something else???
cheers
Edited by mazz
https://www.sau.com.au/forums/topic/91270-new-skyline-from-the-auctions/
yeah like there doesnt seem to be a huge leak of oil any where :S could the mechanic have forgottent o put oil in(doubt it). im not worried about the black smoke cuz i think its petrol not oil but where did the oil go?
the car drives normally, th eoil pressure seems fine and so are the temps? there is no gray/white smoke :S
Edited by mazz
Change the oil again and check it every day to see how much oil it is using.
Black smoke means its running rich - not oily so you may not need to rebuild the engine. It may just need to be looked at by someone who knows what they are doing.
A *little* oil around there is not a big issue, but check the O2 sensor thread. Apparently Nissan recommends changing that sensor every 40,000K's and I doubt your mechanic did that. Then hit up the spark plugs if he didn't change those, if he did, find out what went in there and check that they are the right gap and heat rating.
After all that, reset ECU and let it relearn?
Wat happens is the seal on the turbo goes and it will suk oil through the turbo and out the exhaust
it happened to my TX3T and i needed a total engine rebuild + turbo rebuild and a mates 2.6t sigma engine just rebuilt with no turbo rebuild and his shot oil out of the exhaust
a turbo rebuild solved it
yeah im with R31Nismod heer, if u had low oil ud see the warning lighjt and ur oil pressure would be low :S make sure u check the oil after then engine has been off for a while so it can collect,
cheers
btw if there is no grey/white smoke then ur engine is probably fine, if ur losing oil it might be a gasket somewhere, you should get it checked out either way
Edited by bazz
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
