Hi All
so i used to like brousing thorugh teh drag times database? where has it gone?
that timeslip registry above is empty?
is it something with my account, or has it been ditched.
thanks
mick
I agree - there was a lot of crap in there.
If it were to re-emerge (which would be a good thing), then I reckon that it should be a requirement that you post a link to your timeslip.
Bring it back :)
I always thought it was interesting to compare times and see where I was loosing or gaining times against others with similar mods.
yes i agree it was defo excellent.
i think only times accompanied by a timeslip, or are already recognised by andra as a record etc should apply.
timeslip doesnt have to go online, but defo at least emailed to one of the admins of the table etc....
no just letting everyone input what they want themselves...
maybe have a few people that can update it...
Agreed, it's not useful if people can willy nilly post their fully sik fantasies. Only verified timeslips should go on.
I gave up maintaining it. I spent more HOURS than you could ever possibly imagine weeding out the bullshit in that timeslip database and 1 week later we have 15 pages of shit again.
You do not want this job.
Adrians
lol fair enough, if we keep a strict rule that it cant be posted by us (the user) only an admin can update the times etc?
like we post in the thread and the first page is constantly updated by the admin kind of guy. if there is no timeslip it doesnt go on the list.
mick
times with a link to timeslip will only be allowed, I also think a nissans only base is a good idea as I don't really care what times other cars run
Dirty Sanchez .. afraid of the dark!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
