hi has anyone got or know of a wiring daigram for a r30 because i have put a l20,injected 6 into my race car a i dont want to use the whole loom,i want to find out what wires need to be hooked up in the engine loom to make it run,so far i have got fuel but no spark any help would be great,thanks
https://www.sau.com.au/forums/topic/91577-r30-wiring/
I'm pretty certain that the looms are basically the same between the L20 and L24. The L20 needs a O2 sensor wire, which uses the (vacant on the L24) pin 13.
PM me a fax number, I can send you the EFI wiring diagram for the L24E. And when I find it, the cross-reference list I created.
https://www.sau.com.au/forums/topic/91577-r30-wiring/#findComment-1655768
  • 4 weeks later...
I know this is a bit old, but I just bought an 1981 280ZX Turbo manual on ebay USA to get a lot of this info we don't have on the L20ET engine compartment, so when it arrives I can post any info you might want from it.
Blind Elk, I would be interested in your cross reference sheet if you could send it to me.
Just need to be notified so I can connect my fax machine to a telephone line.
Cheers All.
https://www.sau.com.au/forums/topic/91577-r30-wiring/#findComment-1714666
I sitll have full access to a wiring diagram for a L24e etc...plus i have a l20et in my car if u need any help. Just takes photos of what u need help with.
George L24E is old hat. I probably have more R30 L24E wiring diagrams than you have, including the supplement that came out for the series 2 & 3 of 84/85.
Most of the questions raised are about L20ET wiring and I am buildsing an 2949cc version of the L series engine, as has been fairly well documented in these pages, hence why I invested in the 280ZX Turbo manual, as I am only guessing, but think the wiring would almost be identical to that of the L20ET in our HR30 Skylines.
And I also have the L20ET enginge that was in my PNV and gross amounts of pics before it came out.
https://www.sau.com.au/forums/topic/91577-r30-wiring/#findComment-1719515
  • 4 weeks later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
