where can i buy these and are they difficult to install ? i want a monster boost gauge with oil temp and a optimal shift indicator if these are available, like can you mix n match what ya have on them ? anyways im in melb where's the best palce to get them and installed if need be ? thanks
https://www.sau.com.au/forums/topic/9199-oil-temp-and-boost-gauges-etc/
  • Replies 43
boost will do... otherstuff is fairly cosmetic unless you're tuning individual parameters yourself.
Depends - i'm not a big fan of guages on the dash, even though they are easier to read sometiems. They draw attention from cops and the like. Another place you can consider is down on the centre console in or next to the ashtray.
Originally posted by DJ_L3ThAL
yeah i wanna do the EL too, where did u get it from and is it easy to install yourself ? whats involved etc ? im aq bit of a noob when it comes tro cars :)
got it from jetspeed but apparently its hard to get them now sum1 told me, and it took about 4 hrs to install.
My car came with a monstor tacho but I don’t wana take it out because they are worth so much. I bought a small auto meter boost gauge to go with it. The boost gauge is good but the tacho is just a waste of space and is really the ultimate toss item. There quite easy to install and the boost gauge is a very worth while addition even if it does cost about $150 with the mounting bracket :)
i disagree... so long as its below the top of the steering wheel then its ok... i got pulled over for a RBT and talked to the copper for a little and he actually thought were i had mine was a good idea rather than puting it on the pilar which is more likely to get me in trouble
lol nah seriously
down calder park fair enough u dont need a shift light cause u know its one straiht road and no one pops out
but when ur on millers rd in altona 4 o clock in da morning.... draging some smart arse in a silvia turbo... u mite wanna keep ur eyes on da road
there for shift light is hand.. not the big monsta tacho.. **** that!!! thats to woggish even for me.... hmmm would look good tho hahah
all u need is a small little light some where so u dont hit that bloody limiter and loose time and get imbarresed by a pices of crap silver.. or r32 hahah sorry nik
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
