ok i just read every post in this thread and im more confused than ever.....does someone have photos or a diagram showing what has been done.....i get that you run power cable from the +ve batt to the relay to the pump, and ground the pump to the chassis.....then how do i wire up the oem pump wiring to the relay? oem +ve to +ve on relay? then oem -ve to relay then -ve on relay to chassis or oem -ve straight to chassis.....hope this makes sense :D
Cheers
Yeh, I don't have a clue what's going on either.
Relay connections...HUH :P ???
This is a diagram I made...from what I've done so far. Any mistakes...
I really need to know what to connect on the relay and where to connect it?
use the original positive feed wire to the pump as the positive trigger for the relay.
a relay is composed of two parts; a coil, and a switch.
so.. you use the positive wire from the original pump installation, onto one side of the coil
then you earth the other side of the coil to chassis. so if the car says for the pump to go, the relay clicks and switches over.
then.. you attach you new big beefy power feed to one side of the switch section.
and then attach the wire from the othe side of the switch section, on a contact that is normally open circuit, to go to your pump psitive terminal.
bingo pumpo working.
therefore, your pic is ok, just needed to add the trigger wire (from original wiring) and work out which terminals are coil, and which ones are the open circuit switch.
look here --> http://www.traxide.com.au/Relay_Info.html for relay terminal piccies and descriptions..
remember, you want to use the contacts that DON'T make a circuit until the coil is activated.
hope that helps.
james.
Edited by heller44
Uhh ok..still clueless!
Maybe I should buy the relay from Jaycar first...
Are there many terminals on it or just the 3...Switch Earth and Positive
Care to elaborate A LOT LOT Deeper for a stupid guy like myself.
ie. terminals...WHAT wire goes WHERE, and in what TERMINAL!!!
I'm a 1st yr Electrician so i know basics, but not that far!!
OK..
So this is it then in the drawing right...
So the positive that was originally goes to the pump goes into the Relay to activate the Coil and turn on.
But how does this Bypass the original Relay used as that is what i wanna do.
I want to re-wire the pump switch, where do i get that switch wire from?
This is for an R33 by the way?
Cheers
Simple. Don't care about modifying the previous install. Still use it to trigger the new circuit as then you will keep all the safety side of it with the ecu controlling the pump turn on and turn off. Use the lil wire that used to go to the positive on your pump to instead go to your coil on your relay.
Even if you lose a volt or two in the run of cable, the relay will still switch reliably as it only needs about 4 volts minimum to pull in.
Don't touch any more of your previous wiring other than taping up or otherwise removing the original pump negative wire. That one is no longer needed.
  • 3 months later...
just a question...
im gonna do this weekend. i read a few pages back someone asking the question "how is the new wiring run from the fuel pump itself to outside the tank?" how has everybody done this? i was thinking of making up a plug of sum sort and trying to use the stock connections on the cap to the fuel tank. but finding empty plugs that are compatible with those sockets are hard to come by, and by that i mean i cannot find any. so how has everybody done this?
uploaded a diagram of what i am going to do electrically but am still undecided on how to get the power into the tank for the pump
any ideas or suggestions would be appreciated
Are you asking about the feed to the pump itself or inside the tank for an aftermarket pump? Outside just twitch and solder and heatshrink the lot. Inside you can do the same but I am unsure that heatshrink will last immersed in fuel. I used crimps done properly.
Edited by heller44
both actually...
what i have done is wired up the "power" side of my relay unit in 6mm2 wire. im gonna mount this next to the other relays next to my battery in the boot. signal wire coming from the ECU obviously goes to the standard relay which is already next to the battery. so what im doing is taking the signal wire from that, using it to energise the coil for the fuel pump relay and using the relay to switch the fuel pump on and off like the stock wiring does... thats all sweet... what i would like to know is how ppl have run their wiring from their relays, into the fuel tank to the aftermarket pump...
pump btw is a bosch 040
When i did my install.. i fed the larger positive wire all the way to the fuel pump itself. I also upgraded the earth wire from the pump to chassis. the only thing i had to do was increase the hole size's on the pump bracket inside the tank for the new wire to fit in. It's easy to do and should really be done i believe.
Edited by mtopxsecret6
did this 2day. also installed my bosch 040 fuel pump aswell. i can honestly say im pretty happy with the results. and i can totally understand how some ppl get confused with the wiring. easy to draw on a piece of paper, a little bit confusing curled up in the boot of ur car. what i was having trouble with was integrating my relay cct into the 33's wiring system. i took quite a few pictures of what i was doing and ill upload them tmrw arvo/nite since im @ my gf's house atm.
if you can spare a few hundred $$$ and a saturday/sunday, id reccommend doing this install. i plan later on 2 get my 33 upto around 260-270rwks and having this mod installed in my car will help with this goal.
and btw, to all those ppl out there who rekn the pump is noisy? wtf r u's all talkin about? the only time i can really hear the pump is when i turn the car over from "ACC" to "ON". the pump runs for <3 seconds and thats it (priming the fuel lines mayb). driving in traffic i cannot hear a thing and at lights with the stereo off and just the sweeeeet noise of the RB engine humming @ 750rmp idiling, i can barely hear it.
I hope you soldered those crimps on the fuel pump, and did you run the large earth and positive wire through the original plug? so large wire's.. through original wire on plug then to large wire to pump? thats kind of only going to be as good as the original wire, it will be acting as a restrictor. Some might say it wot make much of a diference.. but.. why do the upgrade in the end if your going to retain some/part of the original wire?? It does look like a nice job, though i would modify those couple of points myself.
I don't see why he needs to solder the crimp connections, as long as he used quality connectors and a proper tool to crimp them.
Though you are correct in saying that the length of original wiring will act as a resistor, resistance is proportional to the length of the wire (as well as the cross sectional area), so considering the length of the original (smaller size) wiring looks like about 5cm, any difference in resistance would be negligible.
Using large diameter wiring all the way through the connector would require repinning the connector, which on some connectors can be a real PITA.
Edited by daisu
go around the connector. it has a rubber boot seal.. cut a slit and go through that way.. pull the wire out and the seal reseal's itself. The crimp provides mechanical strength for the connecion.. the solder provides electrical srength for the connection, being a vibratory piece of equipment.. it could, though may not, suffer from loosness, or tearing from the vibrations etc. Crimps are only the quick and easy option anyway. My dad being an ex electrician always taught me, my work must outlive the component im workng on.
Though it does look like a good job.
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
