I never measured it but you could use a fuse closer to the current draw of your pump. You got me interested so threw the clamp on to my car just then, 9.4A continuous didn't seem to change at all. Driving a bosch 044 intank. I dare say that a stock pump or gtr pump wouldn't use that much, throw a 15A fuse on there, the wiring will definitely handle greater than than the current required to pop a 15A fuse. Measure yours if you want, I don't have any others to compare against.
  • 2 months later...
  • 2 months later...
040 in ur 33 will b no problem
mines been in my car for 8-10 months now and never had any problems...
Yer, so will rewiring the fuel pump be necessary as it is in an r32? Will the same process be used to do so? I went out and bought all the wiring already...
  • 1 month later...
Hey guys, I did this last friday, actually in the exact same way like gumflappers' wiring diagram.
I'm currently running a stock pump, but it feels like it's running smoother through gears, turbo seems to spool a bit better... so my 'gut dyno' says it was worth effort.
But now my fuel warning light stays on all the time... haven't tried to reset the ECU, but I don't think that'll solve the problem.
Anyone who has come across this problem?
Taking the bulb out is no solution haha :P
If somebody could help me out on this one, please do :)
I opened up the fuel pump wiring assembly or whatever you'd like to call it, looked at the pins, but it looks fine, and should make contact (just like it did before I started out modding it)... the pins are locked firmly in the plug, as they were before I even touched them.
This is how I did the wiring;
(I took the relay from the diagram by 'gumflapper').
I first depinned both ground and '12v' feed wire from the plug, then cut off the stock wires from the pins, and soldered the new thicker wire to the pins... the two pins fit well inside the plug and are not loose or something like that.
To get rid of the fuel-light coming on in my gauge cluster, I also tried to get the ground for the pump from the original loom, so the diagram looks a bit like this;
It still had that friggin' light in the gauge cluster :/
I then put it back to the first situation, and took the ground wire from the battery of for about 10-15 minutes, pushed the brake pedal a couple of times, doors open with dome light 'on', etc.
Still has the light coming on :)
What seems weird to me, is that when I meassured the voltage at the three-pin plug, I read a higher voltage when using the ground from the stock pump loom, than when I used a ground from a bolt in the chassis.
What am I doing wrong in all this?
Also, anybody who knows what the two-pin plug is for?
I don't read any voltage from both, with ignition switched on and off, and using the chassis as well as the stock loom for ground.
There's nothing about this in the service manual (that, or I just didn't find it).
Edited by stefan-w
hey
your much better off grounding the pump either to the battery directly or close to it. gounding it thru the wiring lume will reduce the voltage that the pump recieves therefore defeating the purpose of this mod.
in the photo above, you can see the 6mm brown and blue wires that feed the fuel pump. i would be checking the other smaller wires in the tank. i assume (never checked them myself) that they are from the low-level sensor. make sure all of ur wiring is correct and secured/soldered properly and check that all the plugs/sockets are locked together firmly.
however upon looking at that image there seems to be a few more wires in the tank (bottom rhc)... any ideas on what they could be?
I've got ground directly from the battery, just like the 12v feed... it's exactly as in the diagram you made :banana:
Only I used black and red wiring haha, the loom only powers the relay.
That second diagram I've posted was a try, to see if that would solve the problem (wich it didn't, so I went back to your wiring diagram).
Only now do I see you've pulled but wires to the pump, not just to the plug on top of the tank (wich I did)... this shouldn't make a difference I hope?
I'll do so when upgrading the pump, but not on the stock one.
Is that unprotected wiring and an open plug floating around in your fuel tank? :dry:
Are you sure that's entirely save?
i thought the same thing when i took out the stock pump (WTF r all those wires floating around in my fuel? :S) i decided not 2 fix what didnt seem broken... lol
"Only now do I see you've pulled but wires to the pump" i dont understand :S
Crap... 'typo', and I should have written it a bit more clear :rant:
What I meant; I only replaced the wiring up to the female connector (wich goes on top of the fuel tank).
I noticed just then that you have also replaced the thin stock wiring from the male connector to the pump itself, inside the fuel tank... obviously, I did not.
I don't think that'll cause my light to come on though, but I'm no expert.
replacing the wiring to the fuel pump inside of the tank itself will have nothing to do with the low-level sensor... 2 b honest i could not tell you what the sensor even looks like as ive never pulled it out. i had enuf trouble getting the fuel pump in and out let alone the low-level sensor.
  • 3 months later...
pidibump!!
I read the whole 12 page thread. Most people talk about r33 or 32 gts or 32 with Aftermarket pump.
What about Stock fuel pump on a GTR 32 with something like 350whp.
Any benefit?
Maybe, that this help you out:
http://www.stealth316.com/2-fuelpumpguide.htm
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
