I never measured it but you could use a fuse closer to the current draw of your pump. You got me interested so threw the clamp on to my car just then, 9.4A continuous didn't seem to change at all. Driving a bosch 044 intank. I dare say that a stock pump or gtr pump wouldn't use that much, throw a 15A fuse on there, the wiring will definitely handle greater than than the current required to pop a 15A fuse. Measure yours if you want, I don't have any others to compare against.
  • 2 months later...
  • 2 months later...
040 in ur 33 will b no problem
mines been in my car for 8-10 months now and never had any problems...
Yer, so will rewiring the fuel pump be necessary as it is in an r32? Will the same process be used to do so? I went out and bought all the wiring already...
  • 1 month later...
Hey guys, I did this last friday, actually in the exact same way like gumflappers' wiring diagram.
I'm currently running a stock pump, but it feels like it's running smoother through gears, turbo seems to spool a bit better... so my 'gut dyno' says it was worth effort.
But now my fuel warning light stays on all the time... haven't tried to reset the ECU, but I don't think that'll solve the problem.
Anyone who has come across this problem?
Taking the bulb out is no solution haha :P
If somebody could help me out on this one, please do :)
I opened up the fuel pump wiring assembly or whatever you'd like to call it, looked at the pins, but it looks fine, and should make contact (just like it did before I started out modding it)... the pins are locked firmly in the plug, as they were before I even touched them.
This is how I did the wiring;
(I took the relay from the diagram by 'gumflapper').
I first depinned both ground and '12v' feed wire from the plug, then cut off the stock wires from the pins, and soldered the new thicker wire to the pins... the two pins fit well inside the plug and are not loose or something like that.
To get rid of the fuel-light coming on in my gauge cluster, I also tried to get the ground for the pump from the original loom, so the diagram looks a bit like this;
It still had that friggin' light in the gauge cluster :/
I then put it back to the first situation, and took the ground wire from the battery of for about 10-15 minutes, pushed the brake pedal a couple of times, doors open with dome light 'on', etc.
Still has the light coming on :)
What seems weird to me, is that when I meassured the voltage at the three-pin plug, I read a higher voltage when using the ground from the stock pump loom, than when I used a ground from a bolt in the chassis.
What am I doing wrong in all this?
Also, anybody who knows what the two-pin plug is for?
I don't read any voltage from both, with ignition switched on and off, and using the chassis as well as the stock loom for ground.
There's nothing about this in the service manual (that, or I just didn't find it).
Edited by stefan-w
hey
your much better off grounding the pump either to the battery directly or close to it. gounding it thru the wiring lume will reduce the voltage that the pump recieves therefore defeating the purpose of this mod.
in the photo above, you can see the 6mm brown and blue wires that feed the fuel pump. i would be checking the other smaller wires in the tank. i assume (never checked them myself) that they are from the low-level sensor. make sure all of ur wiring is correct and secured/soldered properly and check that all the plugs/sockets are locked together firmly.
however upon looking at that image there seems to be a few more wires in the tank (bottom rhc)... any ideas on what they could be?
I've got ground directly from the battery, just like the 12v feed... it's exactly as in the diagram you made :banana:
Only I used black and red wiring haha, the loom only powers the relay.
That second diagram I've posted was a try, to see if that would solve the problem (wich it didn't, so I went back to your wiring diagram).
Only now do I see you've pulled but wires to the pump, not just to the plug on top of the tank (wich I did)... this shouldn't make a difference I hope?
I'll do so when upgrading the pump, but not on the stock one.
Is that unprotected wiring and an open plug floating around in your fuel tank? :dry:
Are you sure that's entirely save?
i thought the same thing when i took out the stock pump (WTF r all those wires floating around in my fuel? :S) i decided not 2 fix what didnt seem broken... lol
"Only now do I see you've pulled but wires to the pump" i dont understand :S
Crap... 'typo', and I should have written it a bit more clear :rant:
What I meant; I only replaced the wiring up to the female connector (wich goes on top of the fuel tank).
I noticed just then that you have also replaced the thin stock wiring from the male connector to the pump itself, inside the fuel tank... obviously, I did not.
I don't think that'll cause my light to come on though, but I'm no expert.
replacing the wiring to the fuel pump inside of the tank itself will have nothing to do with the low-level sensor... 2 b honest i could not tell you what the sensor even looks like as ive never pulled it out. i had enuf trouble getting the fuel pump in and out let alone the low-level sensor.
  • 3 months later...
pidibump!!
I read the whole 12 page thread. Most people talk about r33 or 32 gts or 32 with Aftermarket pump.
What about Stock fuel pump on a GTR 32 with something like 350whp.
Any benefit?
Maybe, that this help you out:
http://www.stealth316.com/2-fuelpumpguide.htm
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
