Ok after replacing the battery for the second time in the two years ive owned the line.....im just wondering if there is any places I can check or look for that would drain the batteries so quickly.
I do not have a sound system so no amp etc.....and I just got your basic alarm system with immobiliser and motion sensors.
Also what is the recommended voltage/size of battery for skylines ?
Finally last question is...can the batter voltage affect the car in any way ?
I think maybe im just being paranoid but the car doesnt seem to "start" as easily compared to the previous battery.
any help would be appreciated..
thanks guys..
https://www.sau.com.au/forums/topic/92067-battery-issues/
hey thomas,
was the alarm installed when you bought the car??
i have a problem with my battery and the alarm is the cause...
goes dead in 2 days if the car isnt started
i got it tested at a normal auto electrician (my dads work)
found the prob in 10mins
https://www.sau.com.au/forums/topic/92067-battery-issues/#findComment-1659816
I have the same problem
Standard Battery started wearing down quickly got down to only lasting 24hrs without the car being started. then bought a new big one which i left for 9 days when i flew home last hols and it went flat after 8 days..bit worried this new one will wear out quickly too.
I have a Viper alarm not sure if the really bright LED would drain the battery or not...its only an LED so i wouldnt expect it to be drawing much.
The alternator is fine and it charges to full capacity when im driving...i have an amp and sub which might not help...
any ideas how i can fix the prob?
I cant listen to the stereo without the battery draining and i noticed the driving lights such the power too....
Not sure if it is related but i get noise and interference through the speakers in tune with the revs (e.g. high pitch whine that gets higher as the revs increase) bloody annoying and only really noticable when the lights are on e.g. at night i have to listen to the stereo bloody loud or not on at all...
Would a capacitor help to smooth out the voltage into my amp? hence reduce the whine?
Sorry about the essay...having lots of probs with the car....
https://www.sau.com.au/forums/topic/92067-battery-issues/#findComment-1661721
having a lot of problems on my GTT as well at the moment regarding the battery... it could be alternator, but car has only done 40000 kms so i doubt it. Grounded the wire from battry to chasis/coilover bolt. Still problems, the battery simply does not charge and if i dont tstart the car up the first time, it will not start up afterwards
https://www.sau.com.au/forums/topic/92067-battery-issues/#findComment-1662058
The alarm drains a surprising large amount of power.. it's not the LED - it's the constant signal it's emitting to all the sensors, sonic detectors.. everything that it's monitoring..
Moving past that though - Most batteries will die after a couple of weeks without the car being started, it might just lose to much charge to crank over the engine. Also it's not about the voltage so much as cranking amps is what is required to get the engine kicking over..
https://www.sau.com.au/forums/topic/92067-battery-issues/#findComment-1662859
Cheers mate
Pretty sure its not the boot light though, u can see the light through the little vents in the rear parcel shelf when its on and i dont see that when the boot is closed.
I have to leave my car for a couple of weeks when i go on hols to qld, i dunno how to stop the battery from draining and setting the alarm off, the gf's neighbours were pretty pissed last time i went away and the alarm went off...
https://www.sau.com.au/forums/topic/92067-battery-issues/#findComment-1663969
Cheers mate
Weird that you all say that... Im still using a fairly small battery in my car. Running 2 amps, and a flashpoint alarm. The alarm has 3 immobilisers plus the little key thing in the dash where u can turn it on and off without using the remote. I'd say that uses a bit more power than ur standard alarms. Also have my gauges hooked up, not sure if they use power to keep memory settings etc.
I've had my battery for over a year and never had any probs. I went away to NZ for 11 days, came back and cranked over no sweat. In theory the amp shouldnt use any real power till your deck sends it the signal. Maybe i got a magic battery?
In regards to the interference as the revs go up, its to do with your earthing. Check your earthing on your car, maybe move it to a different spot and you'll be sweet. The series 2 r33 has a nice little bit of metal down behind the ash tray behind where ur deck would sit with a hole through it . Perfect for earthing with a screw and a nut...
https://www.sau.com.au/forums/topic/92067-battery-issues/#findComment-1664087
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
