  • Replies 263
Posted Images
man, we dont want holden forums reading this.. Its not the car they drive that makes them a bogan its the person!
most of the population drives mainly one of three cars holden , ford, magna... its only chance the offending bogan is in a holden :)
Edited by kezza
R1VAL,
a) as S92 pointed out this is a forum and not a chat room.
B) find yourself a holden forum....www.calaisturbo.com etc.
c) get the hell off the internet and especially skylinesaustralia. your a noob to the internet, you give skyline drivers a bad name spamming the forums with your hatefull crap. get a life if that. you do sound 12 and i think its time you should go to bed.
reading your other posts it seems though your planinng on getting a skyline yourself.
WHO CARES?
we dont want you here, you give us all a bad name and i cant see wat the hell your problem is with holdens. just because you think they are for bogans and fat bitches doesnt mean you have the right to publicly abuse the cars and the drivers.
also,
i wouldnt be inclined to attend any skylinesaustralia cruises after giving your self such a bad name on the internet alone. i hope i never see you on any cruise in my life, simply because you forfill the road with hate and abuse.
hell i doubt you even have a license yet the way your baging the P1 and P2 laws am i correct?
when you finally redeem your license and get your first hand look at the road without mummy in the drivers seat i hope you realise that you are the scum of the road and societys hated garbage.
thats my 2c worth.
thankyou and goodnight.
hay i saw that guy buy a packet of chewing gum and i am sure the nice man at the servo gave him a free vk that way he could drive around in his vp with a car trailer on it and the vk on the trailer and legally he can yell twice as much abuse.....
now heees a thinker..... and a chick magnet.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
