Well after almost 3 years, I can finally say im the new owner of an 88' Silhouette.
Bought it for $6k
Mods: well just an exhaust, Rb25 with Rb30 bottom end, external wastegate and BOV with a T78 turbo and microtech, Has run 310rwhp on 9psi.
Guy will be tunning it to bout 200-250rwhp till i can get use to it and will bump it up gradually to bout 20psi with a cooler. Should make 400+rwhp but this wont be for a while.
Took it for a drive and its not that bad to handle, did give it some and wasnt too bad. exhaust will be getting fixed cause of a slight rattle and a newer clutch will be fitted aswell.
Should be out cruising in a few weeks once i get some more cash for roadie and rego. Pics attached below.
oh and thanks to mike and jaime for karting me back and forth over the weekend to see the car.
https://www.sau.com.au/forums/topic/92144-finally/
  • Replies 78
Posted Images
where's the 32 u promised that ud smoke me with last yr... :)
nice.
p.s - 25/30 and microtech is far from stock.... nor is 300+rwhp and 9psi
liar
lol wrong eug sorry mate try again I looked @ it with bennji & it is not a 25/30 sorry & not 300 rwhp
https://www.sau.com.au/forums/topic/92144-finally/#findComment-1661503
thanks guys, was planning on unveiling its potential at a dyno day.
Mods: Rb25 with Rb30 bottom end, external wastegate and BOV with a T78 turbo and microtech, Has run 310rwhp on 9psi.
https://www.sau.com.au/forums/topic/92144-finally/#findComment-1661566
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
