Even if they allow u on the site they can still refuse it once someone checks it.
I tried "broad minded personB8" once @ Vicroads the lady typed it up on the computer and she said yep no problem, but then she realised what it meant and kicked up a massive stink and got the manager to check it and so on, then i wasnt allowed :D
  • Replies 241
Posted Images
They wont allow me
DR1FT
RAC1NG
P1MP
M1NI was gone.....apparently,but I've definately got ELV1S.
They wont allow JG33GT,2 letters followed by 2 numbers followed by 2 letters are only allowed for Federal plates.
I've had 6 calls from them today,I'll just have to wait and see what they deliver,I've lost track.
All envy me
I just ordered my plate. It can only be spelt 1 way with letters and 1 way with numbers/letters ;)
And i'm gonna keep it, maybe sell when the world cup is on next year and everyone is in the soccer mood :):D
Edited by 180_mph
