Even if they allow u on the site they can still refuse it once someone checks it.
I tried "broad minded personB8" once @ Vicroads the lady typed it up on the computer and she said yep no problem, but then she realised what it meant and kicked up a massive stink and got the manager to check it and so on, then i wasnt allowed :D
  • Replies 241
Posted Images
They wont allow me
DR1FT
RAC1NG
P1MP
M1NI was gone.....apparently,but I've definately got ELV1S.
They wont allow JG33GT,2 letters followed by 2 numbers followed by 2 letters are only allowed for Federal plates.
I've had 6 calls from them today,I'll just have to wait and see what they deliver,I've lost track.
All envy me
I just ordered my plate. It can only be spelt 1 way with letters and 1 way with numbers/letters ;)
And i'm gonna keep it, maybe sell when the world cup is on next year and everyone is in the soccer mood :):D
Edited by 180_mph
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
