Heres my Lozza
Some new Pics at bottom of Page
C33 Nissan Laurel
Inspection Front Bar
Wonder Side Skirts & Rear Bar
Flared and Rolled Guards
Deep Dish Wheels (16" Front - 17" Rear)
Xenon HID Head Lights - Very Bright Artic Blue
RB25det Engine Conversion
5 Speed Manual RB25det Gearbox
Trust TD06 Turbocharger
GTR Frount Mount Intercooler
HKS Air POD
Oil Catch Can
Aftermarket Dump Pipe
Full 3" Mandrel Bent Exhaust w/ Cannon
GTR Fuel Pump
Greddy Type R BOV
Remapped ECU
Turbo Timer
Pivot Air Flow Converter
Triple Layer Radiator
Twin Thermo Fans
Twin Plate Clutch
Nismo 2 Way LSD
Short Shifter
Kei Office Coilovers (Everything Adjustable)
Rear Adjustable Camber Links
Cusco Front and Rear Strut Bars
Cusco Front and Rear Swaybars
5 Stud Conversion All Round
GTR Brakes
Slotted Rotors
8 Point Roll Cage
Boost, Water Temp, Oil Temp & Oil Pressure Gauges
Nardi Personal Steering Wheel
R32 Seats
Raised Bonnet
Zip Ties in Front Bar
Power
Made 300rwhp @ 1.1 Bar
Pictures
Edited by j_insoll
https://www.sau.com.au/forums/topic/92608-nissan-laurel-rb25det/
konect - Yes the car is RWC and Registered, driven probably 2 or 3 Times a week.
jimbeam - I did not fit the TD06, a Japanese Guy did..........
Sky80 - Lier - I fitted an Oil Catch Can, Bride Seat, and put zip ties in the front bar. :lol:
But yes all the work was done in Japan
very nice... it must be much more relaxing to drift in a Laurel than a cramped up Silvia :D
I've got a TD06 waiting to go onto a RB25DET, so I'm very keen on finding out what engine mods and management you've got to support the beast.
very nice... it must be much more relaxing to drift in a Laurel than a cramped up Silvia :rolleyes:
To the Monkey that just so happens to be Funky........... :huh:
Mods are as per posted in the List at the top. Apparently the car has a 'Chipped' ECU, although we have taken a look and dont think it has been touched, though we could be wrong. The Injectors are also Standard RB25det Item. You most likely have the Trust TD06-20g. Mine I 'believe' is the Trust TD06-17c. As far as I know the 20g uses The Single Blade type wheel and the 17c uses the Double Blade type wheel (The 20g is the newer version obviously). I hope im making sense. Im currently running 1 Bar (14.7psi) and It makes full boost at around 4500rpm. Obviously this is a bit Laggy, although I have a feeling the Actuator/Wastegate may be a little bit loose, causing a bit of unwanted Lag. I have had this problem in the past.
With a RB25det, Upgraded Fuel Pump, 550cc Injectors, POD, Frount Mount, Exhaust and a Power FC, you should be able to put out approx. 340rwhp @ 1.3 bar. That would be my guess from what ive experienced with my car. Id guess it to spool up around 4000rpm. But hey I could be wrong!
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
