I reckon it would make some good numbers with big'ish boost stuffed into it
One of these turbo's is on my short list, along with 2530,2535 etc so I want to get a idea what its like with a bit more boost! 20psi is about right I reckon, that way you get good value out of a turbo upgrade
If you could post a dyno that would be great!
Whats your boost level you have settled for Roy :P
Nice power levels too quincy :)
I have attached my last dyno sheet, I want to see how it compares to the 2510 running 1.5bar. I reckon this turbo would be great for drift
Edited by Chris32
Well, i have to check, what i thought was 17/18psi on recent track days where i was upping the rev limiter, may actually only be 13/14psi.
I want to be running 17/18psi with ocasional hits of 21psi...suppose i need to get my boost gauge hooked back up. I hope it wsa only 14/15psi that i was running That would mean i ran the times at Sandown and at the drags with only 215rwkws & 14/15psi
When you said you picked up 40rwkws at 100km/h, are you coparing two dyno sheets both done in 3rd gear, or is that 4th gear witha sane rev limit?
i got my 32 tuned the other week, it pulled 175rwkw on 12psi and boost come on at around 4000rpm. my mods are:
tomei cams
high flowed non ball bearing turbo
gtr injectors
power fc
hks intercooler
3.5inch exhuast
splitfire coilpacks
bosch 040 fuel pump.
soon ill be swapping turboes and going a gt3071r
Keep the thread on track please. GT2860RS on RB20.
Quincy what A/R turbine housing did you choose, and comments on the actual delivery too please!!
No doubt this will be a subject of interest to Discopotato03 and others.
Same gear, in 4th. You can see how mine drops away power quick quickly after it makes max power. This dyno is done in 4th, you can see how I want more top end!
Very keen to see the results/specs of quincy's 2860 on the RB20 and how it compares to my dyno. Keen to look at other turbo options now
I am going to stick with 16psi for now - just been stuffing around with it all for the past 3 months so want to keep it safe, very safe for the track.
Asked tuner (Ben) if it has any legs left - his response, "somewhere between another 5-10%" So yes can't wait for 20 odd psi when I could handle the risk of it being off the road again.
Dont have a camera at the moment to post up graph, but will ASAP.
Troy - I compared to yours when I had the 3071 couple of months ago, it is very similar to yours in mid range, comes on a little earier, and of course runs out earier.
Cheers
Cam
Cheers
Cam
Good man Cam, that was going to be my homework asignment next time i was speaking to Ben. :)
So you are saying the 3071 came on earlier then my setup, but ran out earlier...or do you mean the 28RS :O
LOL..this is cool, another RB20 on the same dyno with the same good tuner. If there is a better setup out there then lets find it and all go and buy it :D
Wise move running that boost if its going to be used on the track.
Sounds like a good turbo so far, looking forward to comparing dyno sheets and seeing where the 2860 makes power in relation to mine.
Good results so far
3071 coming on earier, Ha ha.. Dog. And didn't run out of puff till 8500rpm. Not much good. So yep mean 28rs.
By the way exhaust housing has to be .64. .86 was laggy and yuk - even though it was advised to get .86 - definatly no good for rb20, must be .64.
Anyone wanting some great honest help should see Wayne at GT Auto in croydon - helped me with everything and he was great.
So you are saying the 3071 came on earlier then my setup, but ran out earlier...or do you mean the 28RS  :)
LOL..this is cool, another RB20 on the same dyno with the same good tuner. If there is a better setup out there then lets find it and all go and buy it :)
Yes interesting about the RB20 not having enough exhaust gas energy to cope with a .86 turbine housing . I guess the bottom line is that its not possible to have the broad flat torque line with 330 cc cylinders . SK did once say in an RB20 vs SR20 "debate" that the RB's advantage was that it could rev and so make the numbers .
With the GT28RS .64 ARR hitting full boost at 3700 rpm it would be interesting to see what raised compression ratios could do before detonation became an issue .
Another thing worth looking into is the GTS-R exhaust manifold , I'm not sure if the std 20/25 exhaust manifold is the same but if it is there could be some small gains in getting the gas speed right here . I think Joels 30DET Pdf shows some pics of RB20 ports but can't remember if the exhaust side are smaller than 25DET .
Does anyone know if the factory did anything significant with the last of the RB20DET's ie R34 if there was such a thing ? If there is an RB20 Neo there's a fair chance Nissan was eager to get the most out of 2L so better manifolds or whatever may be available .
Cheers A .
The Rb20/25 exh. ports are the same size, only differece between the two is the rb20 valves are 'slightly' smaller. Nothing like the size difference between the inlet valves, the 20's inlet valves look like baby's compared to the rb25's.
Edited by Cubes
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
