This Sunday is round four of the Octagon Series at Baskerville.
So far the Skylines entered are a bit lean with a few missing, but still a good mix anyway...
Group A
29 - Rodney Willits - R32 GTR
81 - David Ayers - R33 GTR V-Spec
62 - Stuart Benson - R32 GTR V-Spec II (Don't expect anything to much from me though!!)
Targa Group B
18 - Kerry Kuck - R32 GTSt M-Spec
26 - Mark Perry - R32 GTSt M-Spec (10 points if you can actually read the signwritting)
Plenty of other machinery too with Greg Garwood's 996 Turbo doing battle the wild Targa Torana's of Peter O'Keefe and Kim Barwick. Laurie Williams is running his 20B RX7, there is a coupe of Evo's running too, as well as an STi, RX7 SP, Integra Type R and the ex-Peter Fitzgerald GTP Porsche 968 Turbo RS being run by Mark Connolley from Melbourne. Very cool car and is an awesome thing to drive.
Looks coming out for a look?
https://www.sau.com.au/forums/topic/92652-octagon-series-round-iv/
Wasn't a bad day at baskerville today, a few skylines on track, it was hot as weather... loved the ICS R33 it sounded sweet as!
also a heap of nice imports cruzin around hobart this arvo...
i was followng a real nice white R32 GTR AND R33 GTR with r34 gtr wheels... anyone on here?
cheers...Luke
Apologies for my dismal performance! Water temp was the main cause of my problems. Investigating a new radiator and thermostat already. That said, the day did give me a good chance to bed-in and suss out my new front brakes, which I cam very very happy with... except now I would really like to even out the braking force and therefore need a rear upgrade too!
Contrags to Mark Perry (26motorsport) on winning Group B in the GTSt.
sav man - Pretty much OK for Targa as is. I ran it at Rallye Burnie back in June and they have the same technical rules. The current rear muffler is oversized for Targa, but its too loud in the car anyway so I'm swapping that over soon.
Does this hit the track much? sounds interesting
Its been at the last three Octagon Series rounds and Laurie Williams who owns it wants to run it on the mainland in Sports Sedans....but its still full steel body.
And i think if it runs like it did then he may have a chance over there as well considering the weight of it still!!!!
Mark gets driver of the day and class win again :)
SKYLINE POWER thats all i have to say, and his excellent pit crew :lol:
Hopefully get a few more of us there next season to represent and take it to the older fellas :D
Was a good day racing and look forward to Symmonds now
Cheers B
dunno if i would be elligible for octagon B, but im more than happy to help in the pits for you :)
maybe we can get the kart out :)
or just do club days
My plan is to start with club days and get as much track time as i can so i can get the best set up for the blue pig.
Then it will be Class C next year :)
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
