Here's the calendar link http://www.vhrr.com/calendar.htm#start
Big Pete reckons it's very cool and the ex-Gibson cars will be there so I'm thinking of making an effort on one day to go take a look.
Just thought I'd offer a heads up for racing enthusiasts that have missed this.
Cheers
Geoff
https://www.sau.com.au/forums/topic/92732-sandown-historics-nov-4-6/
Cheers
Geoff
Jeff, i'll give you two tickets for both Sat and Sun. There will be some Ex-Formula One car there as well and a famous guy ( Sir something ) also gonna be there.
Porkas????.....PFFFffft!! 944 isn't a real car. I think the GTSt was quicker at the island :D
I've been pestering Issy at Selectmaz to let me buy his S2 RX7 that was never beaten in Improved Production class. The prick has decided to campaign it next year so I mught just have to build one with his help.
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
