13.4 second 1/4 for your 'stockish' R33. (A how to guide).
Willowbank 24/8/04
1995 white GTS25T
driver mick51
60ft 2.113
et 13.496
mph 104.48
mods nil catback exhaust removed, interior stripped (see pics) Dunlop circuit radial slicks 230x17
mick ran 13..790 at 103.61 on the 205's the car came from Japan on
http://members.optushome.com.au/jay51/Track%20Car/
I haven't weighed it all yet, we were in a rush to get it done by the Sun....Not as much as you would expect though....everything in there is REALLY lightweight. I intend to weigh it when I get time. I've got to scrape off all the insulation that is stuck onto the metalwork. I noticed in the pic that I forgot to remove the rear windscreen wiper/motor....damm!! that might of got us to 13.3
  • 1 month later...
Last week i ran [email protected] with a 2.076 60ft at wsid. Mods as follows:
- Front pipe back exhaust (stock dump pipe)
- Pod filter
- 1bar boost
- 255/35 faulken ziex tyres (18's)
- Bov
- Back seat removed (don't weigh much anyway)
- Thats all i think
Would love to see wat i can do with some grippy tyres.
- Pod filter
- 1bar boost
- Bov
- Thats all i think
Not a bad time there mate for the mods :Paranoid:
My 12's with stock cooler and turbo setup won't be ready by then! If i can crack 12's wit stock cooler an turbo that must be some kinda record???
I dunno wats more owned, stalling on the line or lining up the rear tyres instead of the front like i did! hahahaha
  • 1 month later...
Hi,
Just wondering if there is a r33 with actual (proven) 13 sec passes with the mods indicated in the first post of this message? Just that there is so many posts, and none really that fits the category of the first message.
Hi,
There is my old one and a few others since.
the time slip is on the 'second post'.
here you are.
http://forums.skylinesdownunder.co.nz/atta...=&postid=189495
As for the 'proven' part, I think you will find a few veteran SAU WA members who were present on the nights I ran those times. I ran 13.4's / 13.5's quite consistantly.
13.4 with basically no mods isn't that impressive any more with all these east coast R33's running 12.7-12.9 on stock motors, turbos and radial tyres ?!?!?
Adrian
i'm new to this forum and am hoping that someone will be able to tell me if up gradeing the turbo to one that still will bolt straight on is a good idea? i own a 94 gts-t with a 3inch exhaust heavy duty, brass button clutch pod filter aftermarket bov and a boost tap. soon i will have a front mount....when i know how to bolt it in and an aftermarket ecu. my quest for more power never ends.
can anyone help!!
Hey new to forums.
Car aint a skyline but here goes.
12'7@108mph 1.9 60"
Mods are full zorst, fmic, .9bar, safc2 and filter. Stock motor, turbs and computer apart from safc. RB25
Car is commodore and weighs jus over 1400kg's
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
