13.4 second 1/4 for your 'stockish' R33. (A how to guide).
G'day
I ran a 13.9 with a stock standard skyline and 12 pound of boost. no weight reduction, no exhaust, and $15 205's which REALLY didnt cut it. oh, and VISHES, running street tyre pressure is absolutely crazy. my first run i was, and was spinning third gear quite uncontrollably. does anyone know a site i can upload videos? i have the 13.9 and the 15.1 (stock tyre pressure) on video and time slips. changing tyre pressures will give you large increases in traction. also, another problem is smoking the tyre to much on the line. i have talked to many drag racing professionals that believe with street tyres, its wiser to merely 'clean' them on the burnout pad before staging. let me know wat u think, cheers :P
Hey new to forums.
Car aint a skyline but here goes.
12'7@108mph 1.9 60"
Mods are full zorst, fmic, .9bar, safc2 and filter. Stock motor, turbs and computer apart from safc. RB25
Car is commodore and weighs jus over 1400kg's
How can it be a stock turbo if its a commondore?
  • 2 months later...
guys, i jsut went out and baught a Blitz DualDriven Supersound blow off valve, and since i got it on, boosting thru gear changes has reduced the lag phenominally, when u say u have backfiring yada, half the reason is because u have set tehm too restrictive/loose...
set them up right, and u will have no worries what so ever, atm im getting back fires thru shifting but thats because i loosened up the BOV:D
in a whole wid the BOV its so much "smoother" but the problem with it , is that it feels the car is slower, when infact its not, its just alot cleaner thru the cdhanges, so its not so jerky as to make u feel the car is going super fast....
the aftermarket BOV can not and does not reduce lag over a correctly operating factory one on a stock turbo.
What 'feels fast' and what is fast are often two different things.
The great thing about skylines is that you don't need to spend $100 + on a new BOV to make them do fast times.
  • 2 months later...
nismogtsx,
My carbon canister looks connected, and is at the fuel tank end, the manifold leak..er pipe side I have blocked and rejoined the pipes so they look factory.
smallish open (to canister) holes to your manifold good for performance?
Nope!
how do i disconnect the carbon canister? i dont even know where it is?
  • 1 month later...
Hi,
Just wondering at what RPM you guys are launching your cars.. I've got a SII R33 RB25DET with 3" inch turbo back exhaust, FMIC, 12psi boost standard rims and tyres and I dont think i can even run low 14's. I've tried running approx. 1/4 mile (informal) run and only get 14.5's to 14-8's. I launch at 2500 - 3000rpm with very minimal wheelspin. Flat shift etc. I can beat most mildly standard R33 skylines very easily in the area I live in so they must be doing at least mid 15's.
So can someone who's got an actual timeslip of their time they've run, with a list of mods (remember this is supposed to be stockish)pm me...
Lastly any help on the launching would be good. Thanks.
Steve
scooby_steve,
Have a look at your 60ft times and then check out your terminal speed.
If you have a 60ft of say 2.2 or better and a terminal of 100mph / 160kmh then that is good enough for a 13 second pass.
If you are still in the 90's for mph and have a 60ft of 2.3 or greater that will tell you something about your present time slips.
There is a 'drag' section under the motorsport part of the forums which would be good for you to place a thread under too.
Hi,
I've done one run with a G-tech and i did a 14.5 at 162kph (as stated by the G-tech)... I didnt have a look at my 60ft time though... There was a little wheel spin but was moving pretty well ie, not sitting in the same spot and spinning... what am i doing wrong? I've bought myself a cheap, must be first model G-techs, to practice on so maybe i can better my times.
thanks guys
Scooby_steve,
As you are probably aware the g-tech is simply not comparable to a real drag strip.If you have been to one you know what I mean. The title of this thread reffers to a real drag strip time. You will find the surface on a drag strip quite a bit different to a road surface. In particular you will find there is a finer line of traction to aim at vs a normal road. You need to hit the bullseye between bog down and wheelspin. G-techs will tend to give you a much better time than you will get on a drag strip.
Hey rev210,
i recently attented the NDSOC Drag Day at heathcote and the best time i could do was a 14.07@97mph. My 60' time was 2.1 also.
My current mods are exhaust from frontpipe back (no dump), bleed valve set at 12psi (some cheap brand and may not be reaching desired boost in 3rd and 4th gear), GTR intercooler, Pod filter (no sheild), and the tyres are HANKOOK K104's 265/35/18 at 36 or 37psi (i know its very high).
What do u think my problem is as to why i can't get into the 13's? Also what would u expect a car with my mods to achieve?
Sorry for all of the questions, u probably get a lot of people asking but u seem like u know what u are talking about so i thought u would be a good person to ask.
Thanks, Mike
:D
Hi,
Rev210 I much appreciate your help..I'd love to get to a drag strip but there just aint one near me and I dont feel like driving 4hrs to one (closest one).
So from you've said, I should be pulling roughly bout 15's?. I know a mate who's got consistent 13.4 - 13.5 sec pass (official time from a drag strip, papers and all) and he ran on a G-tech and could only get 13.8's (same setup etc).
Lastly, any launch tips for the time when I get on a proper track? PLEASE? RPM, tyre pressure etc would be great. Thanks again.
Steve
HKS-R33,
You have a fairly low terminal speed. This is most likely a lack of power to make a 13 since your 60ft is pretty good. You are doing the right thing off the line but, perhaps because your Pod filter has no heat sheild you are sucking in lovely hot engine bay air instead of ambient temp stuff, making your power die off.
My old R33 gtst had an exhaust and pineapples only (everything else stock) and ran 13.8's pretty easy on 205's. Get a heat sheild and see how you go.
Scooby_steve,
Bummer you aren't near a drag strip. G-tech's are ordinarily on the side of faster street times but, at the end of the day higher or lower it's not equal. It's probably the best tool you have however to prepare you for the track since you can practice various launches and tyre pressures.
Tyre pressure wise 20psi is usually quite effective for most street compound tryes. I'd say the launches rpm wise you do on the road will need a little more refining once you hit the strip but, it's the best starting point.
  • 3 weeks later...
well i haven't got a skyline, but in my chaser i ran a 14.06 @103mph with a 2.38 60ft time running standard SMIC and running 8.5psi (9.5 on the spike). I just couldn't get off the line even with the auto as i had bald tyre :)
I'm having a guess with a 1.8-1.9 60Ft mark with the same mph i would be in the mid 13's
Well after reading this thread, im fairly convinced this is the way to go, but im interested in cost, as I couldn’t see it anywhere. This is my guess at costs, can someone tell me if I’m on the mark?
$70 .* K&N panel filter inside stock airbox
$700* 3inch FGK cat-back exhaust (very quiet and probably more restrictive than some exhausts)
$200* 3 inch stainless dump pipe off the turbo 'wrapped' with DEI thermal tape to the cat. This dump does not have a sepparate wastegate screamer or feed pipe.
$150* Diff Cradle kit or 'pineapples' , the Whiteline kit No. KCA349.
$600* Ogura Lightwieght flywheel 4.8kgs.
$500* Ceramic puck sprung clutch and stock pressure plate
$20 .* Wrapped turbo to intercooler pipe (DEI thermal tape).
Free * Removed panel behind stock intercooler.
Free * Timing set around 20+degrees advance.
Free * disable the carbon canister fume feeds to the intake.
$100* Turbo smart bleed valve (cheap one) set to 10psi boost
On Car* Simex 205/50 16 inch rear tyres. let them down to 19psi.
$30 .* NGK coppers ...6ES gapped to 0.7mm
$2370 Total Cost???
Now im guessing most of those would be NOT fitted, and not having time/tools to do it, I would guess around $200 for clutch fitting, $50 for pinapples and $150 for exhaust, bringing total to approx $2800?
Thanks
Lee
Hey all i just signed up, i bought myself an r33 gtst (LOVE IT)
i have a problem i was wondering i could get some advice on! since i bought the car it will only run upto 5 pound boost or less. I tampered with the plumbing and managed to overboost the car. I have changed it bk since. i am going to wire the solenoid 2 moro to give constant 7 to 8 pound boost and see if it acually works, gets it upto my desired boost level.
any help would be awesome!
So i have a aftermarket blowoff valve(with a plum back) already fitted to my r33 .3 inch exhaust with a dump pipe no if i change the blowoof valve back to a stock one am i going to notice any differance or shall i just leave it the way it is?
Got my car on the dyno the other day and it was making 173kw on 12psi and 181kw on 13psi. I thought this kind of power was ok for the mods i have. So rev210, u got any ideas as to why my terminal speed is slow?
My boost was actually bleeding from 12psi down to 9psi?
Could this have been the reason?
I recently got a new boost controller from simark87, and it seems to be holding better.
Sorry bout the stupid questions, its just that im going down to the drag strip in the next couple of weeks and dont wanna be stuck in the 14's again.
P.S: Check my post further up for mods and time etc.
Thanks for ur help
Mike
Thanks for ur help
Mike
What kind of ECU are you using? What are your Air/Fuel ratios like?
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
