13.4 second 1/4 for your 'stockish' R33. (A how to guide).
nismoR34
i crossed the line at 8k, and engine came off power badly. thats the way i got 13.872.
but if i shift into 4th it should be much better. i didnt mean for it to go to 8k.
whenever i changed to 4th i would get a 14.2-14.5
maybe i should imporve my shifts. (4th gear grinds) i need lighter oil.
8,000rpm isn't as healthy as 7,000rpm. If you aren't making power at 8,000rpm why rev it there and cop the extra wear?
At sustained revs beyond 6500rpm the standard pulley ratios will cause the water pump to cavitate.
Looks like a waste of time to me, hardly bigger just get a FMIC, I know your against it REV but someone already beat you to a 12sec pass with a stock turbo using a FMIC so they can't be all that bad with the stock turbo.
I ran a best ET of 14.4 yesterday @ heathcote.. Only had about 4 runs to try a few things unfortunately as it was pretty busy. Track was rain effected, so not sure whether that brought times down.. None of the other 5 SAU cars there could get under 15 for a stock(ish) car. Its not easy - not many VIC GTS-T guys are getting into the 13's with the stock ECU/turbo combos at all???
Tried 225/50's on stock 16" rims.. Didn't make much difference as far as i could tell as to traction..next time i will just use my street 235/45 on 17"s...
Guest INASNT
i noticed u were getting really bad launches and all of your runs 2.
wheel spin sux.. got aftermarket suspension, pineapples, and reasonable street tyres (ok, not the best, but should be enough) - not sure what else i can do to be honest.. I was getting 60' of 2.5's or so which isn't great.. even if i can knock that down to a low 2s if i got a good launch (damn helmet - can't hear shit), thats still only a 0.4s gain and only going to get me into high 13's..
After 2nd well just floored it and banged it into each gear right on 6,500 as quick as possible and foot right back to the floor .. to me they seemed like perfect changes - not sure whether i can do anything to improve that part?
I tried a bit of changing into 2nd at lower revs (5000rpm).. didn't seem to help - u just lose the speed which counters the increased traction.
Hey, I got a 14.7 before the rain kicked in [again] :)
I basically lost 1st gear to wheelspin on my 14.7 run which had a 60ft of 2.63 - this was my only run with traction control ON!
Surely the GTR-700 can do a better time than low 9's with a TS of 164.9mph? ~ I am suggesting all times were slow due to the rain-drenched track. They should have cancelled the meet but I dont think they wanted to lose the money :rolleyes:.
my quote from another thread:
my best of 14.7 is not exactly the car's potential IMO, but a bit more respectable than my first 2 efforts: 19 and 16.97 ha ha!
I think starting with a wet track was never going to be an easy task - my drag strip driving methods will be improving [i already know how to drive the car on the street].
I am a bit pissed off about the rain / times really but the day was good and the support / enthusiasm from everyone was great! thanks.
we have some good video footage too - online soon!
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
