13.4 second 1/4 for your 'stockish' R33. (A how to guide).
  • 1 month later...
check out time slip.
Front pipe, cat and exhaust.
Boost up to 12 p.s.i
Unshielded Pod. (shield now on, but not during run)
BASS OUT
rev210 is correct. Standard Turbo, Standard Intercooler, Standard Computer.
  • 4 weeks later...
  • 4 weeks later...
I just had a bit of a test run on a friend Passport G-Timer to see what to expect roughly with my new mods, since running a 14.1 with catback and pod.
I now have a cold air box with HKS filter, 3" catback exhaust, S-AFC2 and bleed valve with the car dyno tuned to run 11psi - running stock suspension and 255" rear tires. With the boost set to 10psi (don't entirely trust the bleed valve since I found it gets boost spikes on the road) the more notable results were:
0-60mph - 4.93
0-100mph - 12.05
0-60ft - 2.05
330ft - 5.78
1/8th - 8.78 @ 83.2mph
1000ft- 11.33
1/4 - 13.47 @ 105.3mph
Run was done with mechanically sympathetic gearchanges, I think there would be a bit more in it :D
0-60mph - 4.93
0-100mph - 12.05
0-60ft - 2.05
330ft - 5.78
1000ft- 11.33
Run was done with mechanically sympathetic gearchanges, I think there would be a bit more in it :cheers:
Thats a crazy 60', sure you dont have attessa hiding there somewhere? lol
Shame i dont remember all the rest of my stats (namely 8th mile data) to compare, looks like the whales could all have a good go with each other.
Lith,
If you look at my old time slip at the start of this thread thats a mid 13 time for sure. However the g-tech reading was not done on a drag strip surface? If not you might find the time is going to be generous by comparison. If you get the same 60ft time on the real drag stip you will certainly be getting that time however.
Lith,
I agree completely, hence the fact that I am quoting my 14.1 @ 103mph time on my sig as my cars performance - despite the fact the car has a lot more power than it had when I did that time, as until winter ends there is no chance to prove its new potential :cheers: Anyone who knows me will know that I don't like to give myself false hopes, that time was just used to get an indication of progress and I posted it because it was an interesting comparative result.
Out of interest, the used road surface IS actually quite difficult to launch on (and there is the whole fact that being winter, its not going to be a nice sticky surface) - the launch method was virtually driving off from stationary and giving it gas when it was rolling (basically a 2000-2500rpm slip then floor it) which still resulted in some spin (despite quite good 255s)... but was easier to control from lower revs etc. 2.05 60ft indicates a very good launch, but because of the nature of the technique I wasn't carrying as much speed at the end of the 60ft as from slightly higher revs :)
How on earth can 107.6mph = 109mph??   Especially when 13.68 equals 13.6?   A
Talk about optimism
I thought it was 108.7? Ahh well, i couldnt actually remember, and i knew if i put up roughly what it was you would correct me anyway hahaha~ Hence the "optimistc" ness, you would notice it faster lmao
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
