hi pplz i need a lil bit help
im chasing 350rwkw i had 300 but was to laggy
im getting the heads posted and polised today and new valve springs
also looking into some low comp pistons, maybe a gt35/40 also some stonger rod bolts i have the ignition setup already and fuel set up
i need some ideas the more the better also i also have a high mount manifold waste gate and im after some ideas for ecu
thanks
https://www.sau.com.au/forums/topic/93107-wanting-over-350-rwkw/
hang on, you just said 300rwkw was too laggy but you want more power? dont expect less lag? have you considered a 3 litre bottom end? adding another 50rwkw is only going to add "more lag" if you don't make the engine more efficient at the same boost level and / or turbocharger size
a healthy shot of nitrous will help you get there for a split second or two :P
this is just a idea n i dun no much bout the rb25s but im about 2 (rb25det neo coming for my r31 wagon this weekend :-D )... its prolly too late to say this now and might be innefective but wat about a neo head would your computer handle variable valve timing???... that got em a extra 30 kw or so along with bigger coil packs n some other stuff (pretty sure)
not bad thanks pplz i dint think ill be going to the 3lt bottom end would love to but cash might be a issue how hard is it to do
and wat does it cost
i had a t70 was a bit laggy but i still producced just over 300 rwkw on 19psi i think i want a high mount and also a ball bearing turbo for quicker spool
i need to know has anyone reground there cams as i heard this is a option instead of buying some
5000 rpm
im getting a high mount
need to know wat turbo to use i wat it earlier than that
i had a t70 standard manifold with custom dump pipe setup bosch 044 spitfires now im getting port and polish also wat are the best pistons im goin 20thou over
well my GT30 used to get on the money (17psi) around 4000-4200rpm, thats on the street, no "preloading" on a dyno or whatever.
That was 300rwkw at a max with that.
You want a bigger GT35, 350rwkw... its gonna be a little better than what you have now... maybe 500rpm at a stab.
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
