hi pplz i need a lil bit help
im chasing 350rwkw i had 300 but was to laggy
im getting the heads posted and polised today and new valve springs
also looking into some low comp pistons, maybe a gt35/40 also some stonger rod bolts i have the ignition setup already and fuel set up
i need some ideas the more the better also i also have a high mount manifold waste gate and im after some ideas for ecu
thanks
https://www.sau.com.au/forums/topic/93107-wanting-over-350-rwkw/
hang on, you just said 300rwkw was too laggy but you want more power? dont expect less lag? have you considered a 3 litre bottom end? adding another 50rwkw is only going to add "more lag" if you don't make the engine more efficient at the same boost level and / or turbocharger size
a healthy shot of nitrous will help you get there for a split second or two :P
this is just a idea n i dun no much bout the rb25s but im about 2 (rb25det neo coming for my r31 wagon this weekend :-D )... its prolly too late to say this now and might be innefective but wat about a neo head would your computer handle variable valve timing???... that got em a extra 30 kw or so along with bigger coil packs n some other stuff (pretty sure)
not bad thanks pplz i dint think ill be going to the 3lt bottom end would love to but cash might be a issue how hard is it to do
and wat does it cost
i had a t70 was a bit laggy but i still producced just over 300 rwkw on 19psi i think i want a high mount and also a ball bearing turbo for quicker spool
i need to know has anyone reground there cams as i heard this is a option instead of buying some
5000 rpm
im getting a high mount
need to know wat turbo to use i wat it earlier than that
i had a t70 standard manifold with custom dump pipe setup bosch 044 spitfires now im getting port and polish also wat are the best pistons im goin 20thou over
well my GT30 used to get on the money (17psi) around 4000-4200rpm, thats on the street, no "preloading" on a dyno or whatever.
That was 300rwkw at a max with that.
You want a bigger GT35, 350rwkw... its gonna be a little better than what you have now... maybe 500rpm at a stab.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
