Guest Pearman
Hi,
I have been told that during winter months, salt is used to breakdown ice on japan’s roads. I’m also told that this leads to higher levels of rust in jap cars.
Questions,
What do you guys think? Found much rust in your cars?
If so, where are the problem areas / common places to checkout?
I also here that AM body kits are sometimes used to hide rust, etc
Any comments…
Thanks
Pearman
https://www.sau.com.au/forums/topic/9324-rust/
It doesnt snow that much in Japan. The mainland and the south in particular (where the most people live) is more prone to temperate/sub tropical climate which has typhoons and torrential rain in winter, humid wet summers.
Sapporo however is usually covered in snow during winter, but thats about 1.7 million people out of 126 million. Not that many cars really :P
I dare say the problem exsists, but its probably fairly uncommon. If your worried, id check things like chassis rails and subframe parts.
Red17
https://www.sau.com.au/forums/topic/9324-rust/#findComment-140159
Yeah just have a good look under the the car... ie subframe etc...
I checked out mine before i bought it and was really impressed with the condition of the car in terms of rust, mainly because i found absolutely none... japan would be alot less harsh in terms of rust than us here on the east coast of australia i think?
https://www.sau.com.au/forums/topic/9324-rust/#findComment-140171
Sapporo however is usually covered in snow during winter, but thats about 1.7 million people out of 126 million. Not that many cars really :)
It sounds like you know alot about Japan, but I'm confused. Have you ever been to Japan?
I just came back from two weeks in Japan where I was based in Tokyo and backpacked around north and south of the main island. I caught the Shinkansen to Hiroshima, Kyoto and Nagano.
It was snowing all the way to Hiroshima (Kyoto is on the way), it snowed in Nagano (obviously), and even snowed in Tokyo the day after I left.
From my brief experience and most importantly talking to people who live there and/or have family there, it seems that Japan sees a LOT of snow in their winter.
https://www.sau.com.au/forums/topic/9324-rust/#findComment-140201
Ok maybe im wrong then, damn university education lets me down again. These authors of text books should really stop publishing lies
Red17
BA (Geography)
hehe...
Makes sense, my degree was full of outdated procedures and programming languages... Silly University :)
In any case, as I said, I was only there for two weeks, so I'm hardly an authority on Japan, but the impression that I got was that they get their fair share of the white stuff ;)
https://www.sau.com.au/forums/topic/9324-rust/#findComment-140227
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
