  • Replies 65
I want to get my wiring harness protector plastic bit dipped in carbon fibre but it sits right next to the rocker covers and would get quite warm. Maybe the fuse box cover too.
I also want to get my fuel rail and regulator painted but i have no idea what finish or colour im after yet...
Hey guys i have heard back from the guy that does the dash, he said the following:
Hi Mass,
The price for r33 dash is normally around $420.00 plus GST but if there is a
few of the other guys that want it done I can do them for $350.00 plus GST
as long as the parts are all in raw plastic.
The reason why I say this is because some of the r33 interior parts had a
soft feel finish coating sprayed on to them from factory and that needs to
be removed. It takes allot of time to remove it because you have to be
careful not to damage the plastic underneath. If your parts have got this
soft feel coating on them I could remove it for an additional $50.00
I will attach some carbon fibre pictures for you to look at that I have just
competed.
If you need any more info please do not hesitate to ring me on 0412 865 066.
Thanks.
Michael.
i havent negotiated more as yet, but just wanting to know who wud be interested and at wat price we shud be aiming for??
i think that if we can get it done for $350 no matter what, as in no more then $350 then thats a good price.
any thoughts? and also i need about 5 people, so far there seems to be about 5 so looks ok....
i see no pic?
keep in mind that my car isnt here yet guys....but if its here when this happens id be interested.
when you say the dash, is that all of it, or just the main part?
look at UAS (www.nismo.com.au i think) and their package coats a shit load of parts....would look really good i think
and you might have to really work at that $350 deal. he's saying $350 + GST + $50 to remove that stuff...
edit, saw the pic. looks hot!
Edited by dezz
i see no pic?
when do u get ur car?
its supposed to get on the boat nov 10th, so end of november it should be here technically. thats un complied etc of course, but i guess if this was going ahead, and i wanted to get in on it, i could go to the compliance work shop and take the surround out? or would that need to be in there for compliance?
at the end of the day, ill prolly miss out, but what can ya do ay :D
I can't find it on UAS. Can you post a direct link please?
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
