  • Replies 65
I want to get my wiring harness protector plastic bit dipped in carbon fibre but it sits right next to the rocker covers and would get quite warm. Maybe the fuse box cover too.
I also want to get my fuel rail and regulator painted but i have no idea what finish or colour im after yet...
Hey guys i have heard back from the guy that does the dash, he said the following:
Hi Mass,
The price for r33 dash is normally around $420.00 plus GST but if there is a
few of the other guys that want it done I can do them for $350.00 plus GST
as long as the parts are all in raw plastic.
The reason why I say this is because some of the r33 interior parts had a
soft feel finish coating sprayed on to them from factory and that needs to
be removed. It takes allot of time to remove it because you have to be
careful not to damage the plastic underneath. If your parts have got this
soft feel coating on them I could remove it for an additional $50.00
I will attach some carbon fibre pictures for you to look at that I have just
competed.
If you need any more info please do not hesitate to ring me on 0412 865 066.
Thanks.
Michael.
i havent negotiated more as yet, but just wanting to know who wud be interested and at wat price we shud be aiming for??
i think that if we can get it done for $350 no matter what, as in no more then $350 then thats a good price.
any thoughts? and also i need about 5 people, so far there seems to be about 5 so looks ok....
i see no pic?
keep in mind that my car isnt here yet guys....but if its here when this happens id be interested.
when you say the dash, is that all of it, or just the main part?
look at UAS (www.nismo.com.au i think) and their package coats a shit load of parts....would look really good i think
and you might have to really work at that $350 deal. he's saying $350 + GST + $50 to remove that stuff...
edit, saw the pic. looks hot!
Edited by dezz
i see no pic?
when do u get ur car?
its supposed to get on the boat nov 10th, so end of november it should be here technically. thats un complied etc of course, but i guess if this was going ahead, and i wanted to get in on it, i could go to the compliance work shop and take the surround out? or would that need to be in there for compliance?
at the end of the day, ill prolly miss out, but what can ya do ay :D
I can't find it on UAS. Can you post a direct link please?
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
