This may seem obvious to most people but for some it is obviously not something they have any idea about.
If someone is organising an event....Dyno day, Cruise, Skid pan, Track day etc. They need to know numbers to ensure it is viable, there is no short fall in funds and that suitable numbers are catered for.
Therefore
If someone asks for interest DON'T say "YES" I'll be there if you probably can't go or if you are unsure. I have organised many events and this problem keeps coming up. You give people heaps of notice and yet they still can't organise themselves.
This is not on and the practice should stop NOW.
So, from now on if there is an event being organised please don't put your hand up without thinking and if you do and later find out you can't make it then e-mail the organiser as soon as you know you can't make it.
Remember, you won't be hated for not going only if you don't tell anyone or give false impressions. I know some of you guys are young and you don't like to commit yourselves but this totally screws things up.
https://www.sau.com.au/forums/topic/937-dont-say-youll-go-if-you-cant-read/
hey cam, i'm guessing this was brought on by the track day??
although i did say i would be going i was called away (on short notice) to go overseas for work. i did try to get the msg to you and even told a few (then) SDU guys to pass on the message.
sorry if it screwed you up any but it was out of my control. but i'll definately be at the next meet. cheers dude
Yeh that's cool. I don't mind so much if people guinenly (spelling) can't go to something but some people just stick their hand up without thinking. It wasn't JUST the track day but also my Dyno day.....Sub Zero said they were coming with 6 cars and didn't show at all???? But then again that's sub zero.
  • 3 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
