  • Replies 277
Posted Images
It was a wonderful day, first cruise i've been on, the ceffie handled it pretty well, and the rain and wind from ippie to brissie.
Cheers to the organizers.
Still eating those sausages?? :O
I have an idea for the next Royal Children’s Hospital Christmas Appeal.
After listening to b105 and hearing where the money goes, etc I feel bad that I spent more money at the petrol station than I put into the bucket…
The bloody petrol companies don’t need the $$
How about we have a Massive Skyline 'Mini' Cruise - this way we could donate our PETROL money to the sick kids.
This year with 100 cars and $2500 we averaged about $25 per car...
Next year, we don't cruise so far (mini cruise) and we put in approx $60 per car or what you would spend on a tank of fuel… with 100 cars this could easily be $6000
It seems to be a great cause, especially at Christmas
Just an idea
I think I was even more nervous this year with having 2 microphones shoved in my face that didn't work, then I got taken up onto the stage and used one of the head sets.
I've asked for the audio file to be sent to me, I rang this morning but it was jsut before the morning crew were going to sign off for the last time so no one was really working around there. I"ll ring again.
Did a good job and heard the nerves in your voice. Of all people, it had to happen to erin with the scretching on the air waves.
In the end. The words finally got out and I found it amazing that Jamie Dunn knew what a skyline was considering he said "dont those guys spend more money on their cars" or something along those lines. hehehe
yeah i was listening aswell. good job. pity about jamie dunn and the morning crews last show though, i used to love listening to them oin my car on the way to work when i had a radio (now the skyline has a jap spec cant get aust radio) but jamie dunn will be on air again he's going to be on air up at noosa on 96.1 the heat in the new year.
  • 1 month later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
