  • Replies 65
This is a very good buy,
as i have / going thru this on a r32 GTr and besides the time involved the costs are heavy to get this hybrid to this stage.
Looks nice - good luck.
  • 3 weeks later...
Here's some pictures of the car it was going to go in so you can all see that the motor was going to power a very highly modified VL Turbo.
It has many modifications, mini tubs, 6 point cage, chassis connectors, 4 link rear end, 9" diff, full floating rear end from Romac, Romac rear brakes and calipers, i was intending on running a high 8sec pass with the motor i'm selling on this forums.
Thanks Aaron.
Guy's,
If you have the money you should buy this. I am sitting here kicking myself in the balls :) as I was given bad advice and am now stuck trying to finish off my RB25/30 Combo :( . I can tell you I have spent more on my engine than you will pay for this. It is a bloody steal.
F$#@ F$#@F$#@F$#@F$#@F$#@F$#@F$#@F$#@F$#@F$#@F$#@F$#@!!!!!!!!
ANYWAY GOOD LUCK WITH THE SALE AS THIS WILL DEFINATELY GO
IF ONLY I HAD SEEN IT IN NOVEMBER LAST YEAR
Cheers
Imtorqing
Guys,
I have to agree with all comments. This is an unbelievable price for this engine. And as mentioned, if it was available in november at that price I would have snapped it up. I am too far into my RB30/25 build now to turn back, but damn would I have loved tomorrows news today on this one!
Dan.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
