Hello All
I have a 1995 GTS-t RB25DET Auto
with th following mods
3'' full exhaust with dump pipe
GCG 450hp Hi flow Turbo
Pod Filter
Hybrid FMIC
Splitfire Coils
FCD
10 PSi Boost
18 degrees timing
My tuner cant seem to get much more then 210hp at the wheels
my ecu is doing the Rich and Retard thing its driving me nuts
What is my options for a ECU for the AUTO or do i go for a full ecu and do a manual conversion.
I would prefer to keep the Auto cause its nice to drive (my missus has to drive it too....with kids....)
I was hoping with startard injectors to hit 250-300hp at the wheels
but it seems that the damm ecu wont let me.
I have been searching the forums for weeks trying to find a clear cut answer to no avail.
Guys i know someone out there can help me
no matter what it still has to retain drivibilty.
HELLLLLLLLLLLLP!
Champ get a compresion test some thing is wrong
i get 242rwhp @ 8psi
mods i have
3' exhaust with hiflow cat hiflow turbo
pod
fmic with plumb back
eboost 2 at 10psi 250rwhp all day
tho my dyno guy was very suprised
you need a g reddy e manage with ignision harnes there is a good thread on hear
james
mods i have
pod
james
sorry wrong message quoted.
Can you point me to that thread mate I cant find much with the search funtionalty
cheers
Speak to a guy on these forums called toshi
He remaps rb25 ecu's. This means he will write a new map for your standard computer so you will retain factory auto settings.
cost is something like $300 + dyno time from memory :blink:
he has done heaps of ECUs and knows what he is doing
Cheers:)
PMDW
some thing is wrong with your dyno results
they are soo low i hav less mods than you and push wat you are after without an ecu auto as well that is y your thread interests me
was the car in second gear wen dynoed?
is it serviced much?
is it a good operater?
how long have you had it?
james
james
he is running a bigger turbo... there is probably nothing wrong at all.
@ 10psi his bigger turbo is more than likely moving more air, spinning out the ECU more than yours.
I wouldnt worry about the figure at all.
Get an SAF-C II onto it and go from there
R31Nismoid
Dont you think 210HP not KW is a little low for the mods he has
and will a bigger turbo lower the over all HP
I thought they just lagged more
210 hp =150 kw @rw
sorry i think some thing is up with that
james
Actually you are right on the money the more airflow is maxing out the ECU
I have pretty much decided to get my factory ECU remapped when the nismo injectors turn up that way i dont have to dick around with splicing looms and such and everything will work smiko i'm hoping for 230 to 240 rwkw fingers crossed and it will still look factory i'll keep everyone posted.
Thanks for pointing me to that e-manage thread mad34 and the factory ECU IS the way to go.CEF11E cheers mate its gunna save a lot of heartache
R31Nismoid
210 hp =150 kw @rw
james
Miller, the stock ecu sucks, they are not all equal.
Nothing is wrong with his car.
plus its auto also... you loose a good 10rwkw in stock form... more power you put in the more your going to loose :P
but yeah, get some management and then re-asses whats going on as currently you cant really get a good idea.
If something is wrong you could spend ages looking and not find it as there are too many things with a bigger turbo and stock ECU.
Get tuning in there and post up the results.
I'd be interested to see what comes of it.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
