  • Replies 207
Originally posted by inark
lmao that would be an idea.... and can be arranged :P or maybe just a print out of the first page would be enough
yep printout of the first page and placed on every car in the carpark at the beach with his name and his car rego!
hahahahahah
i'm with mznismo, this sh*ts wrong and i can't believe u posted it, and then be so flippant about it. I hope i'm just missing a big joke here and u were only mucking around.... and no, not with another chick.
LOL SHUT UP
i go to the beach for a few hours
and use r plotting against me
ohh guess what happened
some bitch in a sigma
hit an r32 gtr
then drove off
i fixed da whore
i got her plates wrote it on a paper left it on da guys window with my mobnile
he calle dup an hour later told him what happened
now that chick is ****ed
man she smashed his back bumber and side 1/4 panel
****tt
i hate people that drive of like that
esp with good cars
sigma? good car? WTF???
lol
its ok we still love u danny.... well inasnt more so than the rest of us... in a weird.... icky way lol
GOOD WORK!!! ***ing bitch! ppl like that shit me! its like the person who did it to mine and they got caught... but i didnt do anything cause i had a new front bar anyway and it was a pissy scratch.
shes going to get charged lol by the cops hahaha leaving the scene of an accident
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
