Item: R34 GT-T Intercooler, standard
Item Condition: Excellent, used
Reason for Selling: Upgraded to Apexi front mount intercooler
Price and Payment Conditions: $230 excluding postage
Extra Info: Comes with the 'rare' plastic intake shroud
Contact Details: PM me, 0427 803 556, or [email protected]
Will post anywhere in Australia, buyer to pay postage costs. Maybe TNT Express is the way to go, or Australia Post registered? (that way you get a consignment number and tracking facilities)
Comes fully flushed & fin-picked only around 1500kms ago, so it is in excellent condition and order.
Great for up to 200rwkw - see 'R34 Intercooler' thread in the Stagea section.
Brendan
https://www.sau.com.au/forums/topic/94215-r34-gtt-intercooler/
It fits a R33 & R34 definately......
& thanx to J_R32 for the infoon the R32 fitment.
I bought it only 3 months ago here on the forums and had it on my Stagea, but found a Apexi fmic on ebay for a price I couldnt refuse, so hence the resale of this R34 intercooler.
Brendan
It's not a straight swap for the R32, but it's only a minor modification. There's someone who did the job recently and they were charged approx $50 (?)for the labour involved to fit it.
Hey Brendan,
Just a few q's
1. 'Rare' plastic intake shroud, are you refering to the standard Stagea intake shroud? Or is this a custom made one?
2. Quote for postage up to Tamworth?
3. Wouldnt need another flush yet would it?
Cheers mate,
Chris
PM Sent....
1. rare shroud is a R34 shroud, a series 1 Stagea shroud is a R33 unit, therefore the R34 shroud is around 23% larger.
2. sent you an offer.
3. nup, perfect clean condition.
cheers for the questions AMS!
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
