RustyR32Gtst Posted November 10, 2005 Share Posted November 10, 2005 I've just bought a n R32 GTS-T which has a remote oil filter kit and i want to know if there is a correct procedure to change the oil and filter ? Any help would be great thanks ! Link to comment https://www.sau.com.au/forums/topic/94392-remote-filteroil-change/ Share on other sites More sharing options...
MerlinTheHapyPig Posted November 10, 2005 Share Posted November 10, 2005 um... drain oil remove filter replace drain plug & filter fill... Link to comment https://www.sau.com.au/forums/topic/94392-remote-filteroil-change/#findComment-1704086 Share on other sites More sharing options...
RustyR32Gtst Posted November 10, 2005 Author Share Posted November 10, 2005 I've just bought a n R32 GTS-T which has a remote oil filter kit and i want to know if there is a correct procedure to change the oil and filter ? Any help would be great thanks ! <{POST_SNAPBACK}> I was asking because the lines to the remote filter would be emptied of oil. I thought that this may have been a concern ! I've done plenty of oil changes before, but none with a remote filter. Link to comment https://www.sau.com.au/forums/topic/94392-remote-filteroil-change/#findComment-1704193 Share on other sites More sharing options...
chicane Posted November 10, 2005 Share Posted November 10, 2005 The oil drains to the sump anyway.. so id suggest just do it as normal. Link to comment https://www.sau.com.au/forums/topic/94392-remote-filteroil-change/#findComment-1704422 Share on other sites More sharing options...
MerlinTheHapyPig Posted November 10, 2005 Share Posted November 10, 2005 I was asking because the lines to the remote filter would be emptied of oil. I thought that this may have been a concern ! I've done plenty of oil changes before, but none with a remote filter. <{POST_SNAPBACK}> ah yep... sorry for the cynical reply there.. was in a bad mood! it won't be a problem, when you start the car, oil will run through the lines and fill up the filter. when car is off, oil drains out of the filter/lines into the sump anyway. Link to comment https://www.sau.com.au/forums/topic/94392-remote-filteroil-change/#findComment-1705240 Share on other sites More sharing options...
RustyR32Gtst Posted November 14, 2005 Author Share Posted November 14, 2005 ah yep... sorry for the cynical reply there.. was in a bad mood!it won't be a problem, when you start the car, oil will run through the lines and fill up the filter. when car is off, oil drains out of the filter/lines into the sump anyway. <{POST_SNAPBACK}> Cheers guys, i feel better knowing motul is in the sump now ! Average oil temp is down about 4 degrees. Link to comment https://www.sau.com.au/forums/topic/94392-remote-filteroil-change/#findComment-1713062 Share on other sites More sharing options...
Angry Fist Posted November 23, 2005 Share Posted November 23, 2005 I'm needing to change my oil too (already put about 5000km on it since I bought it two months ago!) actually but I haven't tried it before, but going by the description I found on the forum I reckon I should be right. Anyway, just a question, how do I tell a remote filter or if I've just got a regular filter and more importantly, which oil filter do you guys use?? Cheers AF Link to comment https://www.sau.com.au/forums/topic/94392-remote-filteroil-change/#findComment-1738581 Share on other sites More sharing options...
RustyR32Gtst Posted November 23, 2005 Author Share Posted November 23, 2005 I'm needing to change my oil too (already put about 5000km on it since I bought it two months ago!) actually but I haven't tried it before, but going by the description I found on the forum I reckon I should be right. Anyway, just a question, how do I tell a remote filter or if I've just got a regular filter and more importantly, which oil filter do you guys use?? Cheers AF <{POST_SNAPBACK}> The standard filter is a Z145A, Ryco or K&N are both good or you can get a genuine part from Nissan. I've got a Greddy filter on my remote set up. The standard filter will be down on the side of your engine block. A remote filter will usually be found up near the top of the right shock tower. Check out this attatchment..... Link to comment https://www.sau.com.au/forums/topic/94392-remote-filteroil-change/#findComment-1739322 Share on other sites More sharing options...
TokyoTaxi Posted November 23, 2005 Share Posted November 23, 2005 Just my 2 cents........ I have a drain valve installed in one of the oil cooler lines and when I do my oil changes I drain as much as I can from the cooler. I've found that most of the oil does NOT drain back to the sump unless your oil cooler AND lines are mounted above the level of the filter boss on the engine block. Thusly I put a drain valve in place to get more of the old oil out during a change. When I re-fill the sump with oil, I disconnect the ignition control module and crank the engine over for about 5 seconds to pump some oil through the system, then re-connect the ignition and start her up. Oil pressure comes up much quicker so there's less chance of hurting the engine. Yes, you may very well reduce the life of your starter motor but a starter motor is a lot cheaper to replace than a set of bearings Link to comment https://www.sau.com.au/forums/topic/94392-remote-filteroil-change/#findComment-1739929 Share on other sites More sharing options...
W3asel Posted November 24, 2005 Share Posted November 24, 2005 The standard filter is a Z145A, Ryco or K&N are both good or you can get a genuine part from Nissan. I've got a Greddy filter on my remote set up. The standard filter will be down on the side of your engine block. A remote filter will usually be found up near the top of the right shock tower. Check out this attatchment..... <{POST_SNAPBACK}> ahh i see thats a nice engine bay dude very clean lookin sharp like the carbon fibre Link to comment https://www.sau.com.au/forums/topic/94392-remote-filteroil-change/#findComment-1740207 Share on other sites More sharing options...
Angry Fist Posted November 24, 2005 Share Posted November 24, 2005 The standard filter is a Z145A, Ryco or K&N are both good or you can get a genuine part from Nissan. I've got a Greddy filter on my remote set up. The standard filter will be down on the side of your engine block. A remote filter will usually be found up near the top of the right shock tower. Check out this attatchment..... <{POST_SNAPBACK}> Thanks SNISMO, got to say that's a pretty nice engine bay! Good Photo too really explaines everything Link to comment https://www.sau.com.au/forums/topic/94392-remote-filteroil-change/#findComment-1741219 Share on other sites More sharing options...
CeJay Posted December 4, 2007 Share Posted December 4, 2007 I know this thread is old but I thought I'd post here since it's a good thread. Just had the car service, has a remote oil filter. Now they ended up putting about 5 and a bit litres of oil into the engine. Brought then a 4ltr and 2ltr bottle of Motul Chronos 300v. Now I thought the maximum to fill would be 4.5, but they basically said there should not be an issue with overfilling it with oil due to the extra lines running to the remote oil filter and oil cooler. Sounds fair enough, just wondering if it's true. Just most of the other times, Just used a normall 5ltr bottle or 4.5 litre bottle of oil. Link to comment https://www.sau.com.au/forums/topic/94392-remote-filteroil-change/#findComment-3512532 Share on other sites More sharing options...
jeffworld2 Posted December 4, 2007 Share Posted December 4, 2007 i pulled 6 or 7 out of my rb25 with just jap cooler/ filter kit problems that can occur are too much pressure causing leaks etc, but never had a problem. Link to comment https://www.sau.com.au/forums/topic/94392-remote-filteroil-change/#findComment-3513127 Share on other sites More sharing options...
Luke_ENR34 Posted December 4, 2007 Share Posted December 4, 2007 do u fill the oil filter or put any oil on the filter when u put a new one on? Link to comment https://www.sau.com.au/forums/topic/94392-remote-filteroil-change/#findComment-3513262 Share on other sites More sharing options...
jeffworld2 Posted December 4, 2007 Share Posted December 4, 2007 smear some oil on the rubber seal of the filter, then screw it on as tight as you can with your bare hands. if it leaks, tighten a bit more with an oil filter wrench ($10) but it shouldnt have to be very tight Link to comment https://www.sau.com.au/forums/topic/94392-remote-filteroil-change/#findComment-3513282 Share on other sites More sharing options...
benm Posted December 4, 2007 Share Posted December 4, 2007 I had a GReddy oil relocator fitted to my car last week and with all the extra crap in the gtr we couldnt find anywhere neat to mount it on the strut tower like most people do, we ended up fitted it below the engine right next to the sump drain bolt with a little custom bracket. I'm glad it ended up this way because their would be nothing worse than having a relocator fitted only to have oil piss all over the place because it is mounted upside down, that kinda defeats the whole purpose of it, if I wanted to make a mess I would have just left it where it is. Link to comment https://www.sau.com.au/forums/topic/94392-remote-filteroil-change/#findComment-3513286 Share on other sites More sharing options...
jeffworld2 Posted December 4, 2007 Share Posted December 4, 2007 most people install it anywhere that is easier to remove without making a mess. i can bring mine right out of the car without disconnecting anything, change filter and click back in 1 Link to comment https://www.sau.com.au/forums/topic/94392-remote-filteroil-change/#findComment-3513293 Share on other sites More sharing options...
GTR-32U Posted December 4, 2007 Share Posted December 4, 2007 smear some oil on the rubber seal of the filter, then screw it on as tight as you can with your bare hands. if it leaks, tighten a bit more with an oil filter wrench ($10) but it shouldnt have to be very tight dude...I am glad that I am not doing your oil changes....In every oil filter change I have ever done its always been done with one hand only.There is no need to lock them up that tight.Using two hands to tighten up is a bit too much ...but using a wrench to tighten it???? first time I have ever heard of anyone doing this. Link to comment https://www.sau.com.au/forums/topic/94392-remote-filteroil-change/#findComment-3513320 Share on other sites More sharing options...
GTR-32U Posted December 4, 2007 Share Posted December 4, 2007 I had a GReddy oil relocator fitted to my car last week and with all the extra crap in the gtr we couldnt find anywhere neat to mount it on the strut tower like most people do, we ended up fitted it below the engine right next to the sump drain bolt with a little custom bracket. I'm glad it ended up this way because their would be nothing worse than having a relocator fitted only to have oil piss all over the place because it is mounted upside down, that kinda defeats the whole purpose of it, if I wanted to make a mess I would have just left it where it is. hey I like your idea very much.Sure they look good in magazines mounted upside down but I have always wondered how they are changed without making a mess..Any chance of putting any pictures up ? 1 Link to comment https://www.sau.com.au/forums/topic/94392-remote-filteroil-change/#findComment-3513324 Share on other sites More sharing options...
benm Posted December 4, 2007 Share Posted December 4, 2007 Bad quality pics because my phone doesn't like nightshots but you get the general idea... Link to comment https://www.sau.com.au/forums/topic/94392-remote-filteroil-change/#findComment-3513352 Share on other sites More sharing options...
