hey guys, just joined up coz i need some opinions.
moved to qld from south of perth 8 weeks ago. we de-tuned the engine so there isnt any detonation on regular unleaded because wasnt sure if premium was going to be available on the nullabor on the way here as i drove. currently making 285rwhp but we have taken a lot of timing out of it and boost needs to be turned up another 5 pound as well as taking off permanent closed loop etc etc.
unsure who to take it to because have heard reports of qld tuners trying to blow up motors on dyno to get rebuild from owners. preferably need someone who is good with power fc. i want her back up into the 400's and not blow up in the tuning process.
thanks for any help
https://www.sau.com.au/forums/topic/94398-brisbane-tuners/
just to add another opinion i did do a search on the qld section and it showed up bugger all. i looked for 'garage' 'mechanic' 'tuner' 'workshop' and got about 1 result for the place that used to be ADD. i just know of mercury from my mate.
https://www.sau.com.au/forums/topic/94398-brisbane-tuners/#findComment-1704279
Brisbane Turbo and Tuning centre come highly recommended by many people.
Mercury are good and one of the Forum sponsors.
Chapman and Chapman are quite good, they know their stuff.
Milanco are also very good and focus on customer service.
https://www.sau.com.au/forums/topic/94398-brisbane-tuners/#findComment-1704856
You're kidding right?...
https://www.sau.com.au/forums/topic/94398-brisbane-tuners/#findComment-1704942
i have head a Few storIeS abouT one of the above listed workshops and would think twice about going there, dont get me wrong, i have seen some good work come out of there to, why dont you go in and have a first hand look at some of the workshops for your self before you decide on anything.
Mike.
https://www.sau.com.au/forums/topic/94398-brisbane-tuners/#findComment-1705358
Obvisously there are going to always be a few people woth bad experiences. BTTC are the only ones who have done the right thing by a couple of my other mates.
Charlies are CRIMINALS! Every person I knopw that has gone there has been ripped off. Stuffed tunes, false reporting....you name it.
https://www.sau.com.au/forums/topic/94398-brisbane-tuners/#findComment-1706733
what about MazFix ?
If you got a microtech and rotors I hear they are good...
Few things. Depends on what computer is being run, what your car is as not everyone has an 4wd dyno. Because if someone has NO idea, they might be the worlds best tuner with say a motec, but usless on wolf3d. But I would say APC, PITS, or 101. There was a guy up toowoomba way as well, but I think he has moved as the workshop that used to recomend him now uses 101.
https://www.sau.com.au/forums/topic/94398-brisbane-tuners/#findComment-1707518
while this thread is still here and i cbf searching even though i should, does anyone know the website for 101?
They are in Judds Ct, Slacks creek. Pop in a have a chat I don't think their website is very informative. But I try and find it. <_<
https://www.sau.com.au/forums/topic/94398-brisbane-tuners/#findComment-1715861
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
