  • Replies 63
Although personally I would not recomennd this (then again im not all that handy with a jack and spanners either).
Its far simpler to take it to your local suspension specialist, have him throw it up on the hoist and use a rattle gun.
  • 5 months later...
*puts shovel to one side*
As a few recent threads are linking here, i thought i'd link
my piccies of when i installed mine..
Coz i'm that nice kinda guy.. :(
P:S Please stop to admire my leet photoshop 5killz on the arrows ...
i am very interested in these pinapples!! i got my hr31 gts pilarless and it axel tramps badly!!! the bush on the bak of my diff(i think its claed a bush thats what i was told) that is between the petrol tank and the diff, the rubebr bit is broken, and im getin that repaired and see if it stil does it after that if it does ill get these pinapples for sure!
Originally posted by Nismo_Freak
Axel Tramp aka Wheel Hop also leads to broken rear ends, this is frame power being surged when the tire hits the ground and the gears being jarred. Also the U-Joints can suffer when the rear assembly moves out of align.
I'll motion that... i found out the hard way.
one night at the strip... Massive axle tramp... my rear end wasn't too good anyways, but that totally killed it.
Diff mount if snapped/damaged and the bush has just about given up the ghost
:uh-huh:
So me gonna be getting some on the R31 :(
I'm still curious as to what actually causes axle tramp tho... I mean my car is 100% in the dry on the street, i get slight axle tramp in the wet on the street but on the 1/4 i get major major axle tramp all with exactly the same setup.
Is it stiff suspension, soft suspension, faulty part, etc etc
Interesting that you set up the axle for drift?:(
If you guys are having traction issues, make sure you tilt the cradle back, not forward. Also, using hardmount (alloy) spacers and cutting back the stock bushes will rigidly secure the cradle to the body, and goes yet another step forward in assisting traction and reducing axle tramp.
  • 2 months later...
Hey benm wot mods have you done to achieve 192kW @ 12 pounds? I have the same car as you and was wondering what was a good mod for the money, after reading this pineapples review i will certainly get some in the near future. But any other ideas, suggestions? Atm i'v got a 3.5 inch stainless cat back kakimoto exhaust and a apexi pod with a home made heat sheild which utilises the stocky snorkel. I will soon be getting 3 inch from turbo and a high flow cat after that wot would you suggest? I just want a pretty tuff streeter and wanna car that can drift a little better (coilovers so damn exp tho, ah well i can have a wish list).
Is everyone aware that there are three ways to install the "Pineapples",
1-Standard-rear subframe alignment normal
2-Drag-rear subframe declined to promote squat
3-Drift - rear subframe inclined to inhibit squat
Another thing to consider is the state of your stock subframe bushes which contain a fluid to minimise hash ride, noise and vibrations.
In my case two of the four had busted and there was severe movement in the rear end, also very noisy over bad roads and severe wheel hopping when launching hard.
Pinapples only work when installed with the original fluid bushes.
You cannot purchase these bushes from anywhere. You can only buy a subframe from a wrecked car and swap the whole thing over- big job!
Instead i had solid aluminium bushes installed that completely lock the subframe rigid to the chassis.
Very responsive steering and rear end control but extreme harshness thru suspension and vibrations from the driveline at 40-45KPH
  • 1 year later...
Computalign in Nunawading jsut installed mine yesterday.
How much vibration did everyone get?
I get an audible vibration when accelerating hard.
Back end shudders and I don't really like it all that much.
Vibraton is the enemy of everything.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
