  • Replies 63
Although personally I would not recomennd this (then again im not all that handy with a jack and spanners either).
Its far simpler to take it to your local suspension specialist, have him throw it up on the hoist and use a rattle gun.
  • 5 months later...
*puts shovel to one side*
As a few recent threads are linking here, i thought i'd link
my piccies of when i installed mine..
Coz i'm that nice kinda guy.. :(
P:S Please stop to admire my leet photoshop 5killz on the arrows ...
i am very interested in these pinapples!! i got my hr31 gts pilarless and it axel tramps badly!!! the bush on the bak of my diff(i think its claed a bush thats what i was told) that is between the petrol tank and the diff, the rubebr bit is broken, and im getin that repaired and see if it stil does it after that if it does ill get these pinapples for sure!
Originally posted by Nismo_Freak
Axel Tramp aka Wheel Hop also leads to broken rear ends, this is frame power being surged when the tire hits the ground and the gears being jarred. Also the U-Joints can suffer when the rear assembly moves out of align.
I'll motion that... i found out the hard way.
one night at the strip... Massive axle tramp... my rear end wasn't too good anyways, but that totally killed it.
Diff mount if snapped/damaged and the bush has just about given up the ghost
:uh-huh:
So me gonna be getting some on the R31 :(
I'm still curious as to what actually causes axle tramp tho... I mean my car is 100% in the dry on the street, i get slight axle tramp in the wet on the street but on the 1/4 i get major major axle tramp all with exactly the same setup.
Is it stiff suspension, soft suspension, faulty part, etc etc
Interesting that you set up the axle for drift?:(
If you guys are having traction issues, make sure you tilt the cradle back, not forward. Also, using hardmount (alloy) spacers and cutting back the stock bushes will rigidly secure the cradle to the body, and goes yet another step forward in assisting traction and reducing axle tramp.
  • 2 months later...
Hey benm wot mods have you done to achieve 192kW @ 12 pounds? I have the same car as you and was wondering what was a good mod for the money, after reading this pineapples review i will certainly get some in the near future. But any other ideas, suggestions? Atm i'v got a 3.5 inch stainless cat back kakimoto exhaust and a apexi pod with a home made heat sheild which utilises the stocky snorkel. I will soon be getting 3 inch from turbo and a high flow cat after that wot would you suggest? I just want a pretty tuff streeter and wanna car that can drift a little better (coilovers so damn exp tho, ah well i can have a wish list).
Is everyone aware that there are three ways to install the "Pineapples",
1-Standard-rear subframe alignment normal
2-Drag-rear subframe declined to promote squat
3-Drift - rear subframe inclined to inhibit squat
Another thing to consider is the state of your stock subframe bushes which contain a fluid to minimise hash ride, noise and vibrations.
In my case two of the four had busted and there was severe movement in the rear end, also very noisy over bad roads and severe wheel hopping when launching hard.
Pinapples only work when installed with the original fluid bushes.
You cannot purchase these bushes from anywhere. You can only buy a subframe from a wrecked car and swap the whole thing over- big job!
Instead i had solid aluminium bushes installed that completely lock the subframe rigid to the chassis.
Very responsive steering and rear end control but extreme harshness thru suspension and vibrations from the driveline at 40-45KPH
  • 1 year later...
Computalign in Nunawading jsut installed mine yesterday.
How much vibration did everyone get?
I get an audible vibration when accelerating hard.
Back end shudders and I don't really like it all that much.
Vibraton is the enemy of everything.
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
