Hi All,
It's been a while since I posted something on this forum.
You may recall I had an r33 gts-t ser 2 and then upgraded to an Audi S4, thoguht I would show you a few updated pics, and mods I have done so far:
Old Car:
Didn't have much in the way of mods (fmic, turbo back exhaust, upgraded clutch, GTR rims, Power FC, 040 fuel pump - 190 rwkw's)
New:
Mods so far: - H&R C/O's, Whiteline rear sway bar, dual port BOV's, Borla exhaust, Potenza RE070 semi slicks, Defi Bf boost gauge, Samco hoses, RS4 19" rims, GIAC chip, DBA 5000 light weight/slotted, EBC Greenstuff, 5mm spacer
Edited by Robo
https://www.sau.com.au/forums/topic/94644-update-on-audi-s4/
personally i don't see the S4 as an "upgrade" as such but hey..... that's just my opinion... nice car btw
your a weirdo.....
Class, power, style, AWD and the 0000 on the front...... that is damn sure an upgrade...
Always loved the look of this car mate... keep up the good work!!!!!!!
your a weirdo.....
Lay off the sugar and read my post
haha,
It's funny cause I only had it done that weekend.. News travels fast.. :D
I have to know who it is.. This is killing me hah
nice car dude, still factory turbos? k03s or k04s? i thoght they are tiny arent they? hence need 1.6 bar. how about a pair of gtss for an upgrade B)
Edited by GT Skyliner
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
