I know sometimes Bobjane have sets as 350Z owners have upgraded there rims and traded the stock ones in. Maybe if a local one had any go try them on. I have seen a set a while ago at a Brisbane BOB Jane. Don't know if they will fit but hey its a nissan so maybe they will.
https://www.sau.com.au/forums/topic/94775-350z-wheels/#findComment-1713023
yep thats about the going rate... you can certainly find bargains - but thats the normal asking price. My mate actually nabbed his bosses for $500 when he bought a 350Z and changed rims! I would think the others to keep an eye out for once they start coming in is the nice 18" rims off the V35 Skyline coupes... a few of the guys I've spoken to that are privately importing a V35 are changeing the rims and lowering the coupe as soon as they are complied - and they'd look nice on a Stagea I reckon.
https://www.sau.com.au/forums/topic/94775-350z-wheels/#findComment-1720907
clear indicators on the tail lights!!!! i want some! get away from the volvo look. any money for a set of those babys. already got the clear side repeaters.
oh right, and yeah the wheels look very pretty too.
https://www.sau.com.au/forums/topic/94775-350z-wheels/#findComment-1750431
Series 2 stageas had clear rear indicators, just hit up a wrecker or yahoo auctions have them quite regularly
https://www.sau.com.au/forums/topic/94775-350z-wheels/#findComment-1750817
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
