Hi,
As the title suggests I am having a little trouble with my tune on a rb25det with a gt30 bolted on. Mods are as follows:
all supporting fuel mods, pfc Pro, zaust cam gear 3' neg, 3 inch zaust etc etc etc... Oh yea, running 19.5 psi...
The A/F ratios are just below 12:1 but so close you could say 12:1...
after we got the fuel right we started to add timing, but once we hit about 245 kw she started to ping badly, Big Carl had the same setup and made 260 kw... I cant think why I am experiencing this pinging, possible reasons are:
bad fuel?
oil in the intake piping?
F*ck, I dont know :D
any ideas why I am experiencing this pinging? We did not get a chance to wind much timming into it due to the pinging...
Would it be better to add a little more fuel to allow for more timming?
Edited by GunMetalR33
https://www.sau.com.au/forums/topic/94779-gt30-low-mount-tune-results/
  • Replies 53
Posted Images
UPDATE:
Just spoke with my tuner, I was wrong about the A/F Ratio's. They are actually about 11.6:1 which is ritcher than I figured. Also on a power run it seems that the knock is happening at 6,000 rpm at full boost. Had a look at the map trace and I think we are only talking about 3 or so cells of timming that are causing the knock.
If I amend those ignition cells and the knock goes away is it safe to lean it off to say 12:1 and would this make much difference to the power produced? (I am not worried about the final figure on the dyno, I was just expecting more mid range than the tune currently produces).
Experiment with pulling 1 degree timing out when she starts to ping. Trace with the Map trace or you can do it easy with the settings -1 timing but that will pull one degree out everywhere and you dont want that.
Going from 11.6 to 12.0 is not going to make much difference at the wheels
Good luck
cheers,
Yea I have taken -1 out of the entire map just to see if 1 deg would make a difference and it did so now I just have to isolate to cells at around 6000 rpm causing the knock and take a degree out or two.
I would expect, leaning it out a little would make some difference...
i thought retarding the exhaust cam gear was more beneficial?
It might be retarded, now you have confussed me???? I know that it made a benifical difference when I put it on so I must have it right :(
Actually now that I think about it, it was neg 3 deg :P
are you referring to the lack of midrange problem re: injector lag time wrong? or something else. try a dyno run with the dump pipe / exhaust dropped off. see how the midrange compares. may find the exhaust is too restrictive
The lag time won't be an issue as you have tuned the car at the current setting.
With a similar setup i found about a 3rwkw loss dropping mixtures from 12.4 to 11.9 with no other changes.
Out of interest, what sort of response does it have? Any dyno sheet?
Just noticed you are running an rb25 exhaust housing. They are pretty small and may be restricting the flow, but on the up side improved response.
I thought the internal gate gt30 hybrids were using vg exhausts?
Arr, so I am not going to get to much power from leaning off then... The response is not bad. I get full boost (19 psi) at about 4000 rpm.
I will post the dyno sheet tomorrow...
Thanks for all the replies, Oh yea: I just changed the ignition cells that were causing the issues and it seems to have solved the knock issue...
Now I just need a little more power.
hmm what about the wastegate size? may be a bit small and overboost, which wasn't apparent on the dyno?
No over boost is happing cause the PFC tells me the max value for manifold pressure and it never gets higher than about 1.3 bar... Maybe 1.32 but the tune allows for a little over boost...
I'm running a GT30r with a VG30 exhaust housing, (.63 internally gated) and I will let you know how i go with the tune next week.
I'll have Nismo 550cc injectors.
Also, its bolted up on the stock manifold etc, pretty much the same setup.
I have a powerfc also.
man, 19psi? I that a stock bottom end? If so.. thats gonna kill it!
dont use octane booster unless you wanna change your plugs after using it.
If you cant get it working on PULP then there is a problem somewhere.
I'd start with the exhaust side of things.
Drop it and see what happens. You also need to find out the spec/rating of that turbo
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
