  • Replies 53
Posted Images
The thing that bothers me when looking at the dyno print out is that the power is already rolling off before the car even hits max boost. And it seems to take forever to hit it. It may be a whole different story on the street as the settings on the dyno may not load the car up like on the street.
Something else to consider is there is no shootout data on your printout and so (i assume) no correction. In most cases correction pushes the figure up. For example, an 8 degree difference in ambient and inlet temp will give a 3-4% increase in the figure shown on the printout. and thats only one correction.
wow.. 19psi for only 245rwkw..
Hows it feel to drive?
19psi and 245rwkwk.. :( Maybe the dyno is conservative?
The rb turbine is a .6 something, there's no listed specs but thats what they apparently measure up as, the VG30/R34 turbine housings are a .7 something.
Dynos are a good tuning tool only. Its hard to compare dynos and dynos
Examples.
1) Barometer readings and temp readings give corrections readings. All increase or decrease your rwkw. Put in a low barometer reading and your rwkw goes up. My dyno operator barometer was way out, like 980 on the barometer. My figures where always high, 207/215 rwkw (stock turbo) 220rwkw (2530. no PFC).
2
) Ran my car on dyno, only 225rwkw when i ran 12.55@113mph. Car was very very strong as backed up by 1/4 times. Ran a guy with a 244rwkw from a well known Skyline shop, and it wasnt even close on a rolling run. We had about 4 rolling runs and even if he jumped me i could still peg him back and pass.
3) Dynoed with 2535 last night and only pushed 231rwkw (same as dyno no.1 but with fixed barometer, the operator reckons its costed 20rwkw) but car feels stronger than ever.
So my point is, judge by going in with figure A and coming out with B, you should judge your figures by this and not by other dynos. Really the best judge of power is 1/4.
Yea, It was not run in shootout mode
Throw it on another well known dyno to see how it rates and what they think of the setup power/boost you are using.
Always good to grab a second opinion. :(
What EBC are you using? Its working damn well to hold 19psi.
Edited by Cubes
PFC Boost control kit :(
GunMetalR33, when i had my GTRS turbo installed and producing the same power as you on 1.3bar (19spi) i realised after a it got a bit colder i got slight knock. only way i detected this is on my dial display. i dont have a hand controller but i could not hear anything so it was not pinging. would only happen at high rpm. the tuner reduced the boost, richened it up and took timing back few degrees and it made 230@the wheels on 1.2 bar and does not ping anymore. I was told that my exhaust manifold (factory) was too restrictive for the power/airflow. i have just added cams and plenum and new manifold so i will see how it goes back on 19psi now. Ill try repost next wednesday when they retune and let you know.
inlet temps are satisfactory?
to head for 300rwkw with the standard 25 housing would have to be asking for a bit?
it sounds a little like, when cubes had the RB20 turbo on the 3L, the tuner had to remove a heap of timing up top because of the back pressure to prevent detonation.
Unsure if you know.
I dropped the VG30DET turbo on with its .7 something turbine housing. Instantly I was able to run 20-21degree's right the way through, I hadn't tweaked just bumped it up a little, boost is the same.
Up from 15-16 degree's its quite a bit.
if the light was going off, it was most certainly.
its the ping/detonation that you dont hear thats the problem.
if you can hear it... it could well be too late
Unsure if you know.
Sounds good,
What cost would I be looking at if I was to put the vg30 zaust housing on the back of my GT30?
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
