Hey Guys
Im new to the forums. I am think about buying a R33 skyline GTS-T. THe delema im currently having is wether to buy from a dealer or private. I went on the weekend and had a look at a few dealers the best been SEI motors in Dandenong. They had a good selection and i found one i liked and a good price as well. I just wanted to know what was the best way to go. Im trying to way up my options and at the moment it sounds like the dealer is the best way to go because of the warranty.
thanks for your help
Wes
https://www.sau.com.au/forums/topic/94802-new-car/
look around at a heap of private cars before buying from a dealer and then work out if what they are selling is a good price.
a lot of the time they are well overpriced, and the warranties are not really worth much from what i've heard. very hard to get anything out of a dealer once they have your money.
do a search of the forum, should be plenty of helpful info here mate :D
https://www.sau.com.au/forums/topic/94802-new-car/#findComment-1711900
private sale will yield you a better car and at a cheaper price. the warranty from the dealership is useless and not worth the extra $. you can get 3rd car warranties anyway but again not required. private sale should be your best bet and get someone from sau to go along with you to check out a car with you, two heads are better than one. also take pics of the car when you look at it so you can look at stuff when you get home if you forget to check stuff
https://www.sau.com.au/forums/topic/94802-new-car/#findComment-1712020
yeah go private sale. you will get more for your money. i speak from experiance when i say, the warranty is a scam read the fine print. I think it clearly states that it a scam and that the salesman that was so nice, will just yell abuse at you for even asking about the warrenty. The only reason you should buy from a dealer is if your trading in a car, that for some reason u are unable to sell.
https://www.sau.com.au/forums/topic/94802-new-car/#findComment-1712737
When i went to Sei they had a 94 GTS-T with mags, sway bar, exhaust for $15900.00. It wasnt complinced yet but i could only see one scratch on the car and that was on the front bar. Everything else was stock. There was no CD player but it did have a turbo timer. and some speakers the parcel shelf was crap though. He said if i was a serious buyer he could drop the price even more.
He also showed me all the things that need to be changed for it to be complinced. it has 77000 on the clock.
I have also seen a few private ones for $14000.00 it had the same mods but it had 112000k on the clock. it was also a 94 black GTS-T. Another was silver with similar mods for $13800.00. but it had a series 2 front.
Do they all come with four wheel steer or is that an option. most of the private one say four wheel steer. The reason i ask is because i have heard there are a few probs with the four wheel steer.
thanks again
https://www.sau.com.au/forums/topic/94802-new-car/#findComment-1715708
i thought that that included compliancing and everything. No wonder he dropped the price straight away it was $15,990 he then dropped it to $14,990.
Ok i learning so the total price would be $17,990. Now i understand so that how you get the better deal privately. :D
https://www.sau.com.au/forums/topic/94802-new-car/#findComment-1718454
are you in melb? if you want we (or me) can came along to some private sale cars to help you check them out. avoid dealer cars they are rigged and overpriced. for $17,990 you could land a 96 series 2 in stock condition, or should be able to get very close. imho s2 96 will be stacks better than a 94 model series1.
https://www.sau.com.au/forums/topic/94802-new-car/#findComment-1718831
i got my 96 gts-t model for 16k complienced n rwc from a dealer..with warranty. The body on mine is unmarked no scrathes dints, nothing!
3wks back my timing belt snapped, so i called them up and they rebuild the engine (i bent the valves an a few other things) with no hassels at all, without that i would have been 3k outta pocket.
i was warned to change it from them aswell, but i thought, nah she will be fine, but now she is strong as ever.
also SEI motors own a mechanic place which is just across the road from them.. Be very careful with them i saw one car he had advertised adn when i went to look at it the front was really scratched, rust in the boot and under the doors that rail thing was all smashed in (looked like a fork lift hit it when unloading it) adn i go ar eyou gonna fix it if i buy it and he goes no ill just put skirts on for you...i jsut walked off, i didnt want nothign to do with them.
https://www.sau.com.au/forums/topic/94802-new-car/#findComment-1720089
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
