hi ecl.
definitely a totally different kettle of fish! The teg had spoon springs, injen CAI and Trust PE2 exhaust. Not very modded - saying that though the little pocket rocket managed a 121.9kw atw which was quiet impressive compared to stock (roughly 105kw atw). it handled like a dream and the K20A2 in my opinion sounded the goods (most prefer the B18C). i felt i knew the car and what it could do (had an EM1 civic coupe before it).
Jumping into this GTT is hugely different - im still figuring out when the car starts and finishes - its sooo long! can definitely feel the power increase - turbo spools nicely! such a change coming from one of the best handling FWD produced to a rear wheeler with so much power - i think i may need to take a driving course to understand the car better. As soon as my exams are finished i'll be able to spend more time with her and give a better analysis.
Both great cars though - i didnt sell the R to upgrade/downgrade to a skyline - i just dont like owning cars over 75000kms and managed to get a decent price still.
BTW - thanks all for your help re the park lights - sorry for the n00b questions - got the parkers from autobarn today.
Justin
https://www.sau.com.au/forums/topic/95119-intro/page/2/#findComment-1724587
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
