Sydney Window Tinting Group Buy - From Only $150 Per Car
  • Replies 139
Posted Images
Hi,
I'm only looking to tint the 2 front windows on a coupe with framed doors. Will there be any difference in price?
Thanks.
Mikey.
Mikey, give Greg a call and im sure he can sort something out for you
blitzeh, I wanna get teh cef tinted as its heating up like a biznitch on the inside. Is it more for a 4 door in 35% legal tint?
Shan, Greg should be able to sort you out :P Hes looking after all the SAU'ers pretty well so give him a call. Im getting my 4 door 32 done in the next few weeks.
Slim: As per the first post yes this is still available :D
Cheers,
Nick
sweet will give him a call after christmas. Hope he's not busy in the first week of the new year.
HELP!
Got mine booked in for next week! But need help, I still can't decide which % tint to go with! Was thinking 15% but don't want to get defected, on the other hand 35% may not be dark enough to keep the heat out and people from looking into the car!
Any suggestions and/or pics of recently tinted cars!?
Any help will be greatly appreciated!!
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
