Shell has released a new fuel Optimax Exteme.
It is at least 100RON blended with 5% ethanol.
The shell near my house stocks this fuel and I filled up a tank thinking it was regular optimax.
Anyhow, my car stalled, and jerked continuously. It would not start at times, and just ran like crap!!!
I highly recomend you do NOT use this fuel in your skyline, or any high performance nissan!
I took this from the subaru website, and I guess this also applies to forced induction Nissans also...
All model year Liberty B4 and Impreza WRX STi MY99-00 models may experience starting and or drivability concerns if ethanol blended fuel of any level is used and therefore we do not recommend its use.
For a list of Shell servo's that stock this fuel, visit the shell australia website, and follow the optimax extreme links....
Z
https://www.sau.com.au/forums/topic/95126-optimax-extreme-100ron-5-ethanol/
  • Replies 168
Ive used 10% Ethanol blended fuel rated at 98ron, and it was SMOOTH-AS (it was say half a tank of E98 and half tank of BP 98) in my RB25det.
But I wouldnt use E-blended fuel all that much, only in half tank lots every now and then.
Brendan
Apparently if you want top performance on regular pump fuel you'll actually find these ethanol blended fuels provide the best performance as long as you get a TOTAL retune. Else I'd probably steer clear as if you have a highly tuned car it will lean out alot more using an e10 or e5 fuel.
well when i was at 1/4 of a tank, i filled up with regular 98RON optimax, and within 1km of driving, all my problems were solved.
Nissan recomends you dont use it, I have provided my experience with this fuel, Just trying to warn others...
Edited by Zahos
thats the beauty of a remapped ecu just pull battery lead off and leave, come back all is forgoten, i wll only try this with half tanks at first, utilmate 98 plus the 100 stuff.
Edited by race_snooze
hu? Its not a remapped ecu then. :)
I used a full tank of E10 fuel(10% ethanol) and the car ran great,but my current tune is a little rich.Can someone PLEASE post up Shell servos that have 100 octane fuel in Melbourne.I'm going to tune both my Nissans for this fuel.
I'll be following this thread to hear about peoples experiences before I fill up with the stuff. I've got a stock ECU with a couple of mods, so it runs rich as anyway....
http://www-static.shell.com/static/au-en/d...ite_extreme.pdf
It states it in there.
Extensive tests were done, some of which were displayed in a recent issue of Zoom of HPI (can't remember which). Basically, it needed some serious retuning; heavy increase in fuel, as it is less dense, and a huge advance of the timing, with a 16 rwkw increase over normal 98 ron fuel.
if you goto fcai.com.au it says there that nissan dont recomend using any ethonol fuel in any car made before 2004.
hence y i wont use it.
SSS_Hoon
Exactly.
And Iexperienced the problems mentioned:
- difficulty starting
- poor drivability
Edited by Zahos
ummm.... 100ron.... aint japanesse fuel an even higher rating... why would our cars have a problem with it........ obviously its just tuning... reset the ecu should be fine... it will return to factory specs... as in japanesse factory specs where the fuel is a higher octane rating...
as for the ethonol... the media gave it the name its got...... id rather see the FACTs on this fuel.. strait from the product producer..... i dont think it would do much damage at all.... and seriously guys.... most of you would rebuild you engine before the effects this fuel supposably has are noticed....
of course with progameable ecus you would retune the car when using a higher octane fuel... especially if you want to take advantage of the higer octane.... your stupid to think a totally differant fuel wouldnt cause problems.
b/c of the ethanol
Is this comment based on more research, or again is your arse doing all the talking?
How can you determine how often people will re-build their engines?? and secondly, by making that comment you basically admit that you think ethanol WILL cause damage.
Edited by Zahos
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
